Posted June 12, 200915 yr These are rookie questions I know, but I just purchased a sweet low mile 1981 DT 175 and the previous Owner is still looking for the original manual. Can anyone tell me the viscosity and amont for the transmission oil, the spark plug gap, and the spec for chain adjustment? Thanks - Chris
June 12, 200915 yr Moderator These are rookie questions I know, but I just purchased a sweet low mile 1981 DT 175 and the previous Owner is still looking for the original manual. Can anyone tell me the viscosity and amont for the transmission oil, the spark plug gap, and the spec for chain adjustment? Thanks - Chris Engine oil 10w/30 .63-.74us qt (6-700cc)at oil change 1.23-1.41 us qt (7-800cc) at rebuild plug gap (B9ES)=.6-.8mm .024-.032in Chain 40-50mm (1.6-2.0inch) Measured (approx) mid point between the tensioner and the rear sprocket and make sure the tensioner works ok its supposed to be greased at regular intervals but often gets forgotten. Hope that helps
June 12, 200915 yr Moderator Thanks for your quick response Cynic, that helps a bunch. No problem mate enjoy the bike and welcome to the site.
June 12, 200915 yr Moderator Hi Chris, Welcome. I own a Dt175 '81 also but not quite sweet - Yet!! Here it is right now!
June 12, 200915 yr Hi Chris, Welcome. I own a Dt175 '81 also but not quite sweet - Yet!! Here it is right now! is that your blasting shed in the background ?, how are you gettin on with the compressor ?
June 12, 200915 yr Moderator It is and I am going to start blasting this weekend - I hope. If it doesn't work then I will TNT the c*ap off it
