May 31, 200917 yr Will have it looked at when it goes in to have the new rear tire mounted and post up a new thread with an update from there. Until then it sits in the garage. Thanks all I stand corrected ... there is a software issue ! you must have been typing when I viewed your reply as it appeared blank until I went back to it a few seconds later (after my post) .... I would get them to look at the engine before you go to the expense of fitting the tyre ... just in case the engine repair makes the bike not cost effective ! Regards Jim
