Posted May 19, 200916 yr I am trying to find a flywheel puller for my 1975 DT175. I am able to find one that is supposed to fit a 1976. Anyone know if these two bikes use a different puller?
May 20, 200916 yr I am trying to find a flywheel puller for my 1975 DT175. I am able to find one that is supposed to fit a 1976. Anyone know if these two bikes use a different puller? i think it should fit. i think but not sure the 74-75-76 have the same engine. but there seems to be different thing about the clutch plates...anyway. also, i replaced my flywheel on my 76 dt175 with a 74 one. The bike run, the 2 of them are identical. thats all i can say, RAPCO!
May 20, 200916 yr i think it should fit. i think but not sure the 74-75-76 have the same engine. but there seems to be different thing about the clutch plates...anyway. also, i replaced my flywheel on my 76 dt175 with a 74 one. The bike run, the 2 of them are identical. thats all i can say, RAPCO! Hi I have a 75 dt 175 and i managed to get a flywheel puller from Ebay ( Yambits) uk hope this helps
May 29, 200916 yr Same puller as the 1976, You need a 27mm x 1.0 left hand thread puller. They are readily avaliable.
