kevin10529 Posted May 19, 2009 Share Posted May 19, 2009 Fixed my rear flat with ultra seal. Well chuffed. Its a permanent solution to flats so it says on the tin. Anyone used it before, does it work "for the life of the Tyre"? Tyre manufactures don't recommend it......... that figures if it works as good as it says it does!! Link to comment Share on other sites More sharing options...
Imanupstart Posted May 19, 2009 Share Posted May 19, 2009 Brilliant stuff. Used it in my Vara and was pulling screws, nails all sorts of pointy bits of metal out my tyres. Couldn't recommend it any higher. Got some to put in my Bandit at the weekend coincidently! Link to comment Share on other sites More sharing options...
Moderator drewpy Posted May 19, 2009 Moderator Share Posted May 19, 2009 is there a tubed tyre version? Link to comment Share on other sites More sharing options...
kevin10529 Posted May 19, 2009 Author Share Posted May 19, 2009 is there a tubed tyre version? Think it works in both. I'll read the box and get back to you. Link to comment Share on other sites More sharing options...
Moderator DirtyDT Posted May 21, 2009 Moderator Share Posted May 21, 2009 Ride on and viking seal both work in tubed tyres. Link to comment Share on other sites More sharing options...
Moderator drewpy Posted May 21, 2009 Moderator Share Posted May 21, 2009 Ride on and viking seal both work in tubed tyres. cool, any good? Link to comment Share on other sites More sharing options...
barwell1992 Posted May 21, 2009 Share Posted May 21, 2009 do you guys recomend some for my bike ?? as i ride it on a daily basis Link to comment Share on other sites More sharing options...
Moderator DirtyDT Posted May 21, 2009 Moderator Share Posted May 21, 2009 cool, any good? Just to get you home. I have ridden long distances on tubeless with this stuff in. But on a tube I would be scared of the tube shreading. Link to comment Share on other sites More sharing options...
Ttaskmaster Posted May 21, 2009 Share Posted May 21, 2009 Its a permanent solution to flats so it says on the tin. Then it LIES!!!!! This and all similar products are a TEMPORARY fix to help you get home. It simply seals small holes and can still give out if used for prolonged periods or at high speeds. Some can cause an imbalance in your tyres, which is why manufacturers (who have spent many years developing the perfectly balanced tyre) don't really like them. Be advised you can also develop several small punctures and not be aware of it until the tyre finally gives out. Definitely UltraSeal is a good idea, but check your tyres regularly for defects. Link to comment Share on other sites More sharing options...
