MOT test?
hie veryone.
is there a list of set criteria of what will be tested during a bike MOT?
things such as seat locks, on my jawa the seat lock has rusted up and the seat has had the lugs bent open to allow the seat to be removed without having to use the seat lock,
and also the rear tyre (Avon Speedmaster Mk2, relatively old) has gone a bit square but has plenty of tread left and is not perished or cracked, will either of these be MOT failures?
regards
Steve
As long as the seat is secure and will not fly off on it's own, then it won't be a problem.
As long as your tyre has a minimum of 1mm tread depth around 3/4 of the tyre width, then that will also not be a problem.
