oil leak
i have oil leaking from behind the front sprocket does any one know if the oil seal can be replaced witout spliting the crank case.
What bike??
usually you can do this prise the old seal out and press the new one in being a bit careful with the new one i have done it on an RD
Merv
What bike??
Merv
its a dt 230 i beleve the botom end is the same as a dt200
