YZF 750 R 1996 STARTING UP PROBLEM
EwOkIE
This post is 5487 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Thanks for the info on the spark plugs - much appreciated.
Gutted to hear your's now won't rev out, the obvious answer is something is still wet on the bike and is causing the problem - WD40?
Got a some more advice on my bike with it not starting and the low compression - I did some more investigation into what mileage my bike has done since 2002, bascially it's done approx 1400 per year for 3 years, then a year stood, then from 07-08 400 miles, and from 08-09 90 miles. The previous owner would start it once or twice a month in his shed.
Been told that the valves and engine are probably coked up, so put in fuel treatment and thrashed the bollocks off it, redlining every now and then - that was last night a 2 hour blast. Doing it again in the next couple of days.
Started first time this morning - choke still needs sorting though.
This bike is the fastest, most responsive thing I have ever ridden!!!
