Welding a petrol tank
Whats the words of wisdom on welding a petrol tank?
I've drained it and left it with the top off overnight and think that this should be ok - anyone tried this before?? what did you do?
cheers boys
answer to both questions NO, personally i,would wash it out well first, and i never attempted welding, just sealed them
with a decent sealer
Merv
You would be advised to rinse it thoroughly with something non-flammable such as soapy water (I find soapy water helps break down any petrol residue and reduces the risk of combustion).
I would also advise having a dry powder extinguisher nearby or a bucket of sand :D
my tank has pinhole leaks all over. whats a really good sealer?
por 15
merv
Hi
One of my mates used to connect the tank to car exhaust and run car engine push out the fumes and gases and old gases left in are neutral
another one says this :
, I wash the tanks out with parrafin to remove the petrol and keep it, then wash out with soap and water, now weld the tank, once welded fill the tank with your parrafin again to test it, don't use water as it won't search out any minute pin holes. I've been doing this for years without even the slightest pop or fizz, I hope this does help
Thanks guys
I've done it!
I used a combination of soapy water, then letting the argoshield frm the welder run into the tank for 5 minutes then waving the blowlamp over the filler hole (that makes your cheeks clench!) then welding it
typically my welder starting playing up so the weld wasn't as good as I'd like so just to be safe I skimmed it with chemical metal as well.
If you "get it wrong" neither the extinguisher nor the sand will help.
When petrol "burns" in a confined space it is so fast that it is called (and is) an explosion.
Anything flamable is gone in a flash (and a bang) and dependant on the circumstances and the amount of combustables within ----- it may take you, your garage and certainly your petrol tank with it.
If you can purge ut with an inert gas then care is still required and any "test" with a heat source / flame can be exactly as dramatic as the welding attempt itself if the "test" fails.
Worthy of consideation dependant on where / what part of the tank need welding is to fill it (or fill it as near as possible) with water and weld it with the water still in
Obviously you will need to prop it up / support it to leave only the area imediately near to the split empty / dry
If the area / seam that you need to weld will alow this water filling then AT LEAST you will have minimised the volume of remaining vapour.
And wear a decent cricket box ! :blink:
