xt125x
LOL, my DT50 does 50 on a good day :P.
what sprockets are you running?, changing to a larger front sprocket can make a world of difference and on a 125cc you should have enough power to still get good performance.
addition of a free-flowing exhaust and K&N filter will also increase power output (make sure you add bigger jets to your carb)
When changing out sprockets.....if @ all possible.....try to get @ least one sprocket with an odd number of teeth...
It'll make the chain last longer......proven fact. ;)
on my DT it had a 10 front and 52 rear and was doing 35 flat out, im now running a 14 front and 48 rear and can get 45-50mph on a good day
most people say go up 2 teeth a time, i personally have tried that method and found it to be absolute shite on these small bikes.
go down to say, a 45 on the rear and a 16 on the front and see how you get on
dont forget to change the chain when you do the sprockets as they will last longer when changed as a set ;)
personally mate i wouldn't change the sprocket sizes, on your 4-banger it won't make enough difference because the engine's made to be more torquey at low to mid revs whereas a 2-smoke revs high to make the power.
first thing would be (as said above) k&n high flo air filter and a new exhaust system, id personally go with an arrow system, probably the best you can get for that bike. and then take it to be set up at a dyno centre where they can up the size of the jets and get it all running properly.
Hope that helps :)
Tom
  • 3 months later...
Look i was having the same problem with mine
i put 15 in the front an arrow exhoust and it goes 140 KM/H
  • 2 months later...
Strange,
I have an 05 plate XT125x and it will happily get to 55mph. Goes to 67mph at a push.....
All of this with a 6'2" 17stone fatty on it......
BTW this is a bike with stock sprockets and pipe..
my xt125x seems slow can go 45mph no more any ideas how to get more speed from 2005 model
throw it off a cliff top ,for this you will need a chronograff.for accurate f.p.s. :unsure:
  • 1 month later...
thats very hard for you to be
the bike is smal but it has a big hart
im
i big bore mine to 135cc new trasmition kit jugler in the carb KN air filter and it can do 150 km-h any time
yester day i went with a dt125x with fire box only and i didnt give him a chance
dont mok xt125x
those o dont now the bike secrets do not diserve to ride this bike
