Ok
My starter will turn the engine about one turn real slow and then it wil stop of you keep on it it will turn again a and stop but it does it very slowly
i thought maybe the starter is dragging so i checked the voltage drop very little
if i kick it it starts on one turn
i know it will start if the starter will just turn a little faster
also what is making it stop and start again
thanks alot
Usually 1 of 2 problems, of which are 1) ya battery is knackered or, 2) the brushes in the starter need replacing. There is a 3rd option of your reg/rectifier's shot but then only if you've got other electrical problems.
ok well i took it out and drove it about twenty miles
got back and about a hour later went to check the battery i decieded i would hit the starter
it cranked over like it should and it started
its really weird
i would think the battery too but its a brand new battery Dan
i checked the voltage it was at 13.9 volts
i have tried the starter before at the same volts and it was slow and kept stopping
started it four more times tonight and its cranking over right
i dont know what teh problem was but i hope its fixed
thanks alot
if anyone has any ideas of what it could have been or something i might need to do to keep it from doing it again
would be much appreciated
Have you tried a jump start when it is slow turning to see if extra voltage helps, if not you may need to clean starter gear etc, my honda thumpers are slow to turning over start after sitting for a few days but after a run they are much better and one has a new battery
merv
