November 18, 200817 yr Moderator Today i was tidying up the shed, came across the Right hand switch that another RD owner very kindly sent to me to repair my 250 one that had fallen apart inside the kill switch, and also spotted a WD 40 can straw. and thought for a while, I took the straw and warmed it with hot water then flattened it in the vice between 2 pieces of smooth metal end result a flat piece of red plastic just the right size for the widest end of the switch recess, then with a stanley knfe and steel ruler i trimmed the plastic to the correct (or just about)taper then superglued it into the switch, colour is slightly dark but will most likely fade would not fool a concours judge but looks passable for a DIY restore i reckon, the new switch is a NOS 2R8 one you may need a couple of attempts to get the shape right this was mt second attempt but the materials are not expensive this is good for you XS owners as well. Merv
November 19, 200817 yr Moderator Tis good, now all we need is a way to blacken the "blooming" on the plastic
November 19, 200817 yr Author Moderator uh yes that was me cleaning the switch with carb cleaner merv
November 20, 200817 yr Moderator uh yes that was me cleaning the switch with carb cleaner merv the best I can do is use the "back to black" trim polish
