November 15, 200817 yr Just looking through my owners manual at the air filter section, disappointed with that as I like to service my bikes myself. Any one had one cleaned/replaced yet?How much did it cost ?
November 15, 200817 yr you will not need to change your filters for quite a while yet, filters will be around £20 mark
November 15, 200817 yr Author Owners manual says clean 3500 miles, replace 7000 miles must be done by a Yamaha dealer. £50 an hour they charge must be something to do with the fuel injection pressure?
November 15, 200817 yr Owners manual says clean 3500 miles, replace 7000 miles must be done by a Yamaha dealer. £50 an hour they charge must be something to do with the fuel injection pressure? to be fair though, all owners manual say 'dealer' doesnt mean you have to! any jobs like that are surely diy
November 15, 200817 yr Author I had a CBR600RR which is also a fuel injected bike that also had no information on what to remove, or how to get to the air filter in the owners manual. Yet all my previous carburettor bikes (02 Hornet CB600 , 00 CB500) had the information in the owners manual which was 3 screws remove a plastic cover slide old filter out put new one in replace cover and screws, job done. We need a Haynes manual.
November 21, 200816 yr Author I have decided to leave the same air filter on and buy one of these with the money I save instead :)
November 22, 200816 yr Owners manual says clean 3500 miles, replace 7000 miles must be done by a Yamaha dealer. £50 an hour they charge must be something to do with the fuel injection pressure? this is nothing to do with fuel pressure lol. Officially, yamaha will say 'we cant have customers changing emissions related parts, as incorrect installation could lead to excess emissions' (or some similar bollox). What bike manufacturers are doing is following the lead of car manufacturers, by trying to force/scare owners into having all maintenance done by a main dealer. When your filter does need doing (not for a while yet?) there will probably be people who know or information available to access it (cant be that bad!)
November 22, 200816 yr Author Hehe heh, much needed Going for a micron then? Really want one can’t afford one Boo Hoo (crying insanely) there will probably be people who know or information available to access it (cant be that bad!) No one yet with any no how (more crying)
November 22, 200816 yr Really want one can’t afford one Boo Hoo (crying insanely) No one yet with any no how (more crying) have you taken the tank off? its probably directly under the petrol tank
November 23, 200816 yr Author No not yet, I think that is the way I have to go too, the thing that concerns me is that if I disconnect the fuel hose and reconnect it with an air lock in the fuel injection system it may do some damage to the pump as I think they operate at quite a high PSI pressure, there could be a bleed screw or valve to open on the pump to let the air out until fuel flows out. Unless the pump is in the tank in which case the bike will not start until the fuel has been pumped down the tube through the injector and into the engine. (This I think could be OK.) There must be someone on here with some mechanical knowledge it is a case of them reading this then replying .I hope.
November 23, 200816 yr No not yet, I think that is the way I have to go too, the thing that concerns me is that if I disconnect the fuel hose and reconnect it with an air lock in the fuel injection system it may do some damage to the pump as I think they operate at quite a high PSI pressure, there could be a bleed screw or valve to open on the pump to let the air out until fuel flows out. Unless the pump is in the tank in which case the bike will not start until the fuel has been pumped down the tube through the injector and into the engine. (This I think could be OK.) There must be someone on here with some mechanical knowledge it is a case of them reading this then replying .I hope. iv never heard of a fuel pump being killed by an airlock (not petrol anyway). The fuel pump just raises the pressure (with a lttle lift maybe from an nearly-empty tank), you cant burn the fuel pump out cos if it wont deliver fuel, the bike wont run! The injection side is probably 42.5psi 2.5bar, and air in there will result in a little lumpiness or a stall, but will soon get pushed through. Diesel pumps need priming, petrol does not have this problem.
November 23, 200816 yr Author Probably something( to do with the fact I have just bought a pressure washer to clean my sons Mxer , it says in there not to run it without water other wise damage to the pump will occur,) playing on my mind.
November 25, 200816 yr Author Found it there is a small transparent widget thingamybob dangling down off the bottom of the air box in the rear shock area, slid that off ,some goo came out Picture to follow.
November 29, 200816 yr Author The air box is amidships, after 2000 miles the transparent moisture trap was full and needed emptying
December 6, 200816 yr Author The YZF-R125 air box , Now it is just a case of how to get to it. (Getting Happier)
December 13, 200816 yr Author Might dump the airbox and fit a K&N. http://www.knfilters.com/performance_accessories.htm
February 8, 200916 yr Might dump the airbox and fit a K&N. http://www.knfilters.com/performance_accessories.htm be better if they did a n element for it, they seem to work better on the bike all year round, sometimes in the winter an open element causes probs due to too much icy air
February 14, 200916 yr have you found any way to get the air filter box yet? would just about any airfilter fit in there???
