October 16, 200817 yr Hey people ! The power valve works on the 2stroke engines. The YBR isn't one...
October 16, 200817 yr Hi Mate, does the instrument panel go through any kind of a pre check whilst this noise is there?? IE: does the rev counter go to max then return
October 16, 200817 yr Author Hi Mate, does the instrument panel go through any kind of a pre check whilst this noise is there?? IE: does the rev counter go to max then return Mine does not no.
October 16, 200817 yr Mine does not no. i had the same touble with my bike and it was the starter clutch every so ofen it gets shit in there and courses a noise!!
October 17, 200817 yr All of my Fuel Injected Bikes do/did it, the TTR (Carb) does not. pull the power from the fuel pum and it doesn't, job sorted - no noises. Right, now I have a problem, the bike won't start, it ever so slightly does, bu then doesn't - could it be a fuel problem I'll get my coat.........
October 17, 200817 yr OK, solved it. It is the fuel pump. Apparently fuel from the line sometimes evaporates off if you leave the bike awhile. I still don't have a Powervalve, though!!
January 28, 200917 yr For those who tried the link for the SERVICE MANUAL (YBR125ED English version) and it didn't work, there has been an edit and there's a NEW LINK (see above)
