Hey people !
The power valve works on the 2stroke engines. The YBR isn't one...
Hi Mate,
does the instrument panel go through any kind of a pre check whilst this noise is there?? IE: does the rev counter go to max then return
Hi Mate,
Mine does not no.
Mine does not no.
i had the same touble with my bike and it was the starter clutch every so ofen it gets shit in there and courses a noise!!
All of my Fuel Injected Bikes do/did it, the TTR (Carb) does not.
pull the power from the fuel pum and it doesn't, job sorted - no noises.
Right, now I have a problem, the bike won't start, it ever so slightly does, bu then doesn't - could it be a fuel problem :headscratch:
I'll get my coat.........
OK, solved it.
It is the fuel pump.
Apparently fuel from the line sometimes evaporates off if you leave the bike awhile.
I still don't have a Powervalve, though!! :rolleyes::lol:
  • 3 months later...
For those who tried the link for the SERVICE MANUAL (YBR125ED English version) and it didn't work, there has been an edit and there's a NEW LINK (see above)
