ch4v16 Posted August 26, 2008 Share Posted August 26, 2008 the buzzing you hear could be from the side stand switch and it's just basicly telling you it's still down. this usualy only buzzes when it's in N and the side stand is down. hope that helps you on your buzzing. Link to comment Share on other sites More sharing options...
j300 Posted August 26, 2008 Author Share Posted August 26, 2008 the buzzing you hear could be from the side stand switch and it's just basicly telling you it's still down. this usualy only buzzes when it's in N and the side stand is down. hope that helps you on your buzzing. Hi, Thanks for your response.Don't know really it just goes dzzzzzzzzzzt and then stops when ever the ignition is turned on. Big thankyou to oldgitonabike "you've been fantastic mate" got a spark using your method,(jump lead) + different plug ,now running sweet, selecting gears,etc,etc. Can't thankyou enough,I'd have never have found the stand problem. All the best,John. Would love to know for sure what the sound is when ignition turned on,power valve opening ?????? Link to comment Share on other sites More sharing options...
Moderator Airhead Posted August 26, 2008 Moderator Share Posted August 26, 2008 Great news, glad your CDI's OK Link to comment Share on other sites More sharing options...
blackhat250 Posted August 29, 2008 Share Posted August 29, 2008 well guys thats been an interesting epic glad u got it sussed ; iv fked a C,D,I, BEFORE wi the same method . & aye john hes good that old git--- isnt he Link to comment Share on other sites More sharing options...
AAAthreat Posted September 9, 2008 Share Posted September 9, 2008 Would love to know for sure what the sound is when ignition turned on,power valve opening ?????? If im right that should be the PV cleaning itself when you turn the bike on, mines does the same. Link to comment Share on other sites More sharing options...
Pedz Posted September 10, 2008 Share Posted September 10, 2008 If im right that should be the PV cleaning itself when you turn the bike on, mines does the same. yeah, i'd agree. Definitely sounds like the power valve, mine does it when you first turn the ignition on. Try taking the cover off of the power valve and see if it is rotating when you turn on the ignition and if the sound matches the rotation....if you know what i mean. Link to comment Share on other sites More sharing options...
DTXracer Posted September 26, 2008 Share Posted September 26, 2008 yeah, i'd agree. Definitely sounds like the power valve, mine does it when you first turn the ignition on. Try taking the cover off of the power valve and see if it is rotating when you turn on the ignition and if the sound matches the rotation....if you know what i mean. 2 allen key bolts on the left hand side ov the head tkaes these off you can then see the powervalve turn ignition on it should turn fomr one side to the other cheers Link to comment Share on other sites More sharing options...
