August 26, 200817 yr the buzzing you hear could be from the side stand switch and it's just basicly telling you it's still down. this usualy only buzzes when it's in N and the side stand is down. hope that helps you on your buzzing.
August 26, 200817 yr Author the buzzing you hear could be from the side stand switch and it's just basicly telling you it's still down. this usualy only buzzes when it's in N and the side stand is down. hope that helps you on your buzzing. Hi, Thanks for your response.Don't know really it just goes dzzzzzzzzzzt and then stops when ever the ignition is turned on. Big thankyou to oldgitonabike "you've been fantastic mate" got a spark using your method,(jump lead) + different plug ,now running sweet, selecting gears,etc,etc. Can't thankyou enough,I'd have never have found the stand problem. All the best,John. Would love to know for sure what the sound is when ignition turned on,power valve opening ??????
August 29, 200817 yr well guys thats been an interesting epic glad u got it sussed ; iv fked a C,D,I, BEFORE wi the same method . & aye john hes good that old git--- isnt he
September 9, 200817 yr Would love to know for sure what the sound is when ignition turned on,power valve opening ?????? If im right that should be the PV cleaning itself when you turn the bike on, mines does the same.
September 10, 200817 yr If im right that should be the PV cleaning itself when you turn the bike on, mines does the same. yeah, i'd agree. Definitely sounds like the power valve, mine does it when you first turn the ignition on. Try taking the cover off of the power valve and see if it is rotating when you turn on the ignition and if the sound matches the rotation....if you know what i mean.
September 26, 200817 yr yeah, i'd agree. Definitely sounds like the power valve, mine does it when you first turn the ignition on. Try taking the cover off of the power valve and see if it is rotating when you turn on the ignition and if the sound matches the rotation....if you know what i mean. 2 allen key bolts on the left hand side ov the head tkaes these off you can then see the powervalve turn ignition on it should turn fomr one side to the other cheers
