August 18, 200817 yr as if petrol wasnt expensive enough my bike has decided to shed a leak i opened the shed door ready to go to work this morning and thought Phhh sticking of petrol but then i remembered i had it running in the shed before i shut the door but didnt think anything of it got on started riding then had to flick over to reserves thought huh i filled up last night surely not stopped at work with a wet sock and leg iv got a tiny tiny hole in the bottom corner on the side the bike leans at petrol leaking out got home stripped the tank off bike cleaned it degreased.... whats my options? new tank? welded? do they sell repair stuff?
August 18, 200817 yr NEVER weld a tank..... BOOM It can be brazed, but it needs to be washed out with BOILING water first... the steam gets rid of the vapours. A radiator specialist can do it for you Other than that a it's tank from the breakers. If you had an FZR1000 I could help you out, since I got two in the attic (see for sale section) HTH Oliver
August 18, 200817 yr Moderator There are tank sealing kits available Heres one I cant comment on how good they are as ive never used one, theres probably more than this one, just google Motorcycle tank seal or repair
August 18, 200817 yr Author NEVER weld a tank..... BOOM It can be brazed, but it needs to be washed out with BOILING water first... the steam gets rid of the vapours. A radiator specialist can do it for you Other than that a it's tank from the breakers. If you had an FZR1000 I could help you out, since I got two in the attic (see for sale section) HTH Oliver lol a FZR tank hey /....desperate times call for desperate measures lol
August 18, 200817 yr Author There are tank sealing kits available Heres one I cant comment on how good they are as ive never used one, theres probably more than this one, just google Motorcycle tank seal or repair thanks thats what im going to try il let you no how effective it is cheers
August 18, 200817 yr If you have removed the tank, it can be welded. You will need to vent it first. if the hole was caused by rust, then a cover plate will need to be welded on. However, if that is the case it would be better to get another tank.
August 18, 200817 yr I've used a fuel tank liner that I bought on eBay recently, and it worked a treat! Here's the link Same seller I got it from - tonnes of info and no messing about with mixing, just pour it in, swill it about, drain it and then let it dry! Worth every penny!
August 19, 200817 yr I had hole in my petrol tank and i brought some supersteel £5.99 it repaired my tank i have used it a few times read the instructions on how to use it
August 20, 200817 yr I had hole in my petrol tank and i brought some supersteel £5.99 it repaired my tank i have used it a few times read the instructions on how to use it Have used a petrol tank repair putty successfully on a car which would get you out of the poo - but better to look for a new tank or have the old one brazed.
August 20, 200817 yr Moderator Avoid petseal it peels off again the stuff por 13 i beleive from frost is good you get a kit to clean and derust the tank with it make sure yuo do the job properly the first time no short cuts it is a bugger to get out again i know after doing a tank with petseal that started too peel off Merv
August 20, 200817 yr Author thanks again for ur suggestions i bought some PETRO PATCH cleand my tank etc done a 1st coat let it get tacky for 20mins then cut out a small patch coated in it left it on it for few hours then another coat got up this morning stuck the tank on my bike pored petrol in and away i went no leaks i did another coat tonight happy chappy only cost £4.75
August 20, 200817 yr Moderator Best stuff to use is JB Weld. Its petrol proof, waterproof, heat proof up to 500 degrees F - in fact its everything proof - fookin FANTASTIC stuff. Read about it here: LINKY LINKY We've used it for years on our bikes, cars and otehr stuff - brilliant bit of kit.
August 20, 200817 yr Moderator Best stuff to use is JB Weld. Its petrol proof, waterproof, heat proof up to 500 degrees F - in fact its everything proof - fookin FANTASTIC stuff. Read about it here: LINKY LINKY We've used it for years on our bikes, cars and otehr stuff - brilliant bit of kit. And according to Rod my friendly powdercoater you can fill small pits in casings and other things with JB weld and powdercoat em after safely about the only thing they can find to do it. but it is a bugger too sand etc when hard Merv
August 21, 200817 yr Moderator And according to Rod my friendly powdercoater you can fill small pits in casings and other things with JB weld and powdercoat em after safely about the only thing they can find to do it. but it is a bugger too sand etc when hard Merv It is indeed - you need to grind it really - but its proper decent stuff.
August 21, 200817 yr Had a small leak on my XTZ750 Used Plastic Paddings " Leak Fix" good for petrol and sets in 10 mins Took the tank off and stood it in the sun, leak pointed at the sun. Went to Halfords and bought the product £4.79, plus a pencil with a fibreglass tip, used to abrade the surface around the leak to remove paint and make sure you get back to shiny metal, and that the area is DRY and free from petrol. Mixed up Leak Fix and applied 10mins later the job's a gud un
August 26, 200817 yr Author il have to try that as the petro patch didnt work iv ordered some JB weld Cheers Goff il go buy some leak fix tomoz and be ready if it starts again lol determined not to buy a new tank
August 26, 200817 yr Moderator JB Weld is thee Ticket for the job. Had nothin' but good results with it myself.
August 26, 200817 yr My fz tank had quite a few holes, i emptied it out left it a few days then set about welding it, the only prob i had was due to it been that thin i ended up chasing the weld, i think i got halfway across the tank before i filled the holes lol
August 26, 200817 yr Moderator il have to try that as the petro patch didnt work iv ordered some JB weld Cheers Goff il go buy some leak fix tomoz and be ready if it starts again lol determined not to buy a new tank By the time youve spent all that time and money on patching stuff, and found it still leaks, You would have been better buying a used tank off ebay as I said earlier. You should not worry too much about it, just ask the seller if it doesnt leak, save the answer from the seller, ebay will look after your interests if it does. IMHO
August 26, 200817 yr il have to try that as the petro patch didnt work iv ordered some JB weld Cheers Goff il go buy some leak fix tomoz and be ready if it starts again lol determined not to buy a new tank Listen to the old gits Either take it to someone for BRAZING or replace it! I did say this in my first post I have delt with leaking tanks before and ALWAYS brazed them. As Phil found out... it's too thin to weld and weld goes hard and brittle and no doubt it will crack again. THE ONLY WAY to repair a tank PROPERLY is to braze it, as the brazed joint remains flexible and will not crack. The easiest thing would be to buy another tank... you can still sell yours and it would save a lot of hassle
