June 12, 200818 yr I have a 1981 xs 400 and recently lost my keys to it. While replacing the ignition was easy the question is now how do I get the locking gas tank cap off. Is this possible or is getting the gas cap re-keyed a possibility???? thanks
June 12, 200818 yr I have a 1981 xs 400 and recently lost my keys to it. While replacing the ignition was easy the question is now how do I get the locking gas tank cap off. Is this possible or is getting the gas cap re-keyed a possibility???? thanks hi i just had my 79 xs 400 cap picked and rekeyed for 45 buck it only took about an hour
June 12, 200818 yr Moderator you can undo the cap with a bent screwdriver just push it under the lock end, in england yuo can still get keys from a yamaha dealer just from the number or a decent key specialist merv
June 12, 200818 yr you can undo the cap with a bent screwdriver just push it under the lock end, in england yuo can still get keys from a yamaha dealer just from the number or a decent key specialist merv Can you give me a little more detail on the bent screwdriver?? i buy a lot of tanks that have locks & usually end up taking out the pins which is a PIA, Id like to learn how you did that. thanks jeep.
June 12, 200818 yr Moderator Can you give me a little more detail on the bent screwdriver?? i buy a lot of tanks that have locks & usually end up taking out the pins which is a PIA, Id like to learn how you did that. thanks jeep. I presume you mean the cap like this in which case if you have one you can open look underneath it ands see the position of the catch, you can then take a bent screwdriver and push it under the locked one merv
June 14, 200818 yr must be nice to have a key! mine was drilled by the PO so i just use whatevers in my pocket to turn it.
June 15, 200818 yr I presume you mean the cap like this in which case if you have one you can open look underneath it ands see the position of the catch, you can then take a bent screwdriver and push it under the locked one merv thank you sir ,
