my dtr 125 will tick over but only when the choke is on and wont start if its of . also if u try and rev bike it just cuts out .could that be the reeds
Have you set the carb up correctly and made sure there are no blockages ?
Have you left it long enough to warm up?. ( its a heated carb and runs alot better when warm)
I have an idea but want to be sure you have checked the basics first.
yeh carb and reeds have been taken out and cleaned and yeh was running for about 5 mins befor i tryed to turn the choke off .its just every time i try to rev it it cuts out .is that just bad carb setting ?
sounds like some junk in either the jet or the float bowl to me.
i couldnt get the piolt jet out so mabey dirt in there i duna
You need to make sure all the jets are clean.
There is also a power jet that is cast into the float bowl ( the small pipe that connects the float bowl to the main carb body). Try and blow into it and make sure its clear.
i shall blow them out matey thanks alot
i went and bought new spark plug and cap . then striped carb down blew all the jets out and the 1ns what vez told me to do and i moved the throttle pin from the 5mark to the 4 mark on the needle, and it kicks within the first few kicks but cuts out i think i have got the air and petrol mixing wrong(tick over srew,air screw) dose any 1 know what there suposed to be thanks for all your help :D
  • 1 month later...
sounds like a dirty pilot jet. pass a torch tip cleaner thru it and hold it so you can see daylight thru it.
B
  On 13/01/2011 at 23:13, bella9 said:
i shall blow you later matey thanks alot
I thot you and Ves were getting rather friendly. :D
Oh the air screw , is usually 1& half turns out , ;)
Woah!!!
*coughcough*
Bella, check your grammar :unsure:
