SPARKY64
  1. hi could this problem b caused by my piston rings have burnt or wat are the sighns of my piston rings have blown or headgasket has gone
  2. hi could this problem b caused buy my piston rings have burnt or wat are the sighns of my piston rings have blown or headgasket
  3. hi i have a yamaha aerox 50/70kit the bike isnt pulling any weight at all i have tryed new variater an rollers new belt new clutch any more ideas what could be wrong the problem started awhen my belt snapped when i was doing 30Mph thanks markk
  4. update i have purchased a new clutch a mallossi one and im still haveing the same problem the bike isnt pull any white and more ideas please i have spoken to some one about compression and they say that if it was that the bike would take osme starting but its that easy i can start it with my hand with the kick and also he said there would be loads smoke comeing out of exaust is there any possibility that the big spring in the clutch could have gone and it isnt holding as much pressure as it should thanks
  5. update i have purchased a new clutch a mallossi one and im still haveing the same problem the bike isnt pull any white and more ideas please i have spoken to some one about compression and they say that if it was that the bike would take osme starting but its that easy i can start it with my hand with the kick and also he said there would be loads smoke comeing out of exaust is there any possibility that the big spring in the clutch could have gone and it isnt holding as much pressure as it should thanks
  6. does the springs hold the clutch shoes in place if u have msn my email is [email protected] or yahoo [email protected]
  7. have u any idea how i split the clutch to get to replace the shoes and spring as its conected to where the belt goes thanks i would had a picture of the clutch but i dont know how to lol
  8. how thick should the shoes be they look warn and not much on them either the wheel spins when i lift it off the floor
  9. update i have bought a new variater kit and rollers and fitted them and im still having the same problem the bike isnt pulling on accelleration any ideas please thanks
  10. hi thank you for youre reply therer is good compression sum bits are damaged are the clutch shoes them 3red plastic things after we put the new belt on it was running fine but after a few minutes it got slower and till it was doing nothing
  11. hi the other day i was going along the road on my aerox 50/70 kit on and my bike lost power and cut out i started the bike back up and i was doing 5mph max speed for a few meters down the road then the bike just cut out i came home took the casing off an my belt as shreaded me and my brother have cleaned all the remains of the belt out and we have replaced it with the mallossi kevlar belt which was the same as the one that shreadded we have put the bike back together and took it for a test run but now when i accelerate there is only a little power and i dont move at all i can hold the bike still on full throttle with my feet we have cleaned the air filter out and it is still the same does anyone have any ideas what could be the problem the bike is yamaha aerox 50 with a 70 kit on it it is a 2000 reg and as done about 15k thanks hope some one can help me thanks
