bikertec
  1. Took the exhaust system off fitted new gaskets and sealed around everything with exhaust paste. Cured the problem and so much quieter.
  2. bikertec replied to Mond's topic in Yamaha Workshop
    Most shocks are adjustable isn't yours ? Failing that take it for a blast around sheffield, with all the pot holes here it should soon loosen it.
  3. Thnkyou I will give it a try saves me from stripping the carbs down. Makes sense I know my exhuast is blowing slightly tippicle divvies.
  4. It is worth priming if your going to do it right. this is also worth looking at http://www.thegsresources.com/garage/gs_repaint.htm
  5. My bike XJ600N has been stood over the winter and now seems to have developed a problem when revving down, it starts popping. My first thought is it sucking air in through the carbs. but cannot see where. Everything working well revs no probs drives spot on but just pops when I close the throttle. Any help would be appreciated.
  6. Nearly all parts from the diversion 600 should fit. I rebuilt my Divvy 600n from most parts from the 400.
