1975 DT400 Turn Signal/Brake Light Issues
Can you clarify what you are saying here dew?
Ready to Learn
Greetings dew
Flywheel won't come off :(
you mean a 3 legged puller? if so thats the wrong tool and you will risk damaging the flywheel using it!
Ron Haslam Race School
Thats a great review Ray, good to see you enjoyed it
are you using a proper flywheel puller that screws into the rotor?
thats about it tomy, remove the fixing bolt, screw in the puller and tighten the bolt in the puller...bang on the end of said bolt if absolutely necessary!
New boy here ( but an old 'ish man )
Greetings Dave, nice intro but hurry up man get some miles in quick like
MT-09
Greetings keechy, wow the caterham has gone eh? the MT09 looks a great bike
Hi new member from France
Greetings meymacois, yeah the DTMX passion is strong en France
Diversion xj600s Keeps cutting out?
take out all the plugs and leave it overnight for the fuel flooded engine to evaporate off
XS850 clutch won't disengage...
perhaps the plates have stuck together, a common enough problem caused by lack of use?, maybe try rocking the bike back and forth in gear with the clutch pulled and a hot engine?
WR400 F Reving itself ?
still sounds like float height to me though?
using a tap m7
i'd give it to someone to do for you before you make a balls of it
using a tap m7
maybe a 5.5mm if it's in aluminium
Accidental biker
Love it, a big welcome to the motorcycling world from me Neil, have lots of fun and rideouts with your daughter Neil you'll not look back and still young enough at 54 for sure, the YBR was a great choice
Hello - new to the forum.
Greetings Pete, well done Rotherham
Dt 125 x electrics died?
you're welcome, take care
as a temporary fix it would work yeah, and your neutral light will be an indication that all is well...maybe even toot the horn now and again to be sure. Get it fixed properly ASAP I dont like the idea of you riding around with this long term, it would be good if you come back soon and report that you have fixed it properly
yeah that would work but your connections would need to be 100% good, not just a bit of wire shoved in that can be easily pulled out...It looks like you need to repair your loom or get another
Fitting electric start into dt engine
and it's a no from me too, sort out the DTR engine
New Member from Canada!
Good intro shad, hey It's funny how that oil leak from the forks looks like cats...how about that? Greetings
- New member
the only other thingI can think to try to prove the loom is duff is this, unplug the rear brake switch and secure a piece of wire (jumper) between the brn connector to the loom and the battery +, you should find that lights, horn etc now work...disconnect the keyswitch and using your multimeter check the voltage at the loom brn again, you should find you have nothing at that point if your loom is broken. Take the utmost care with the jumper connected to the battery because if you touch any frame components it will spark, so it needs a lot of care. Only do this if you feel competent not because I told you to I cannot be held responsible for any damage caused by your errors. It would be safer with an inline fuse in the jumper too.
do the contacts inside the plug and socket on the ignition switch look ok and check the brn wires are secure?
renovating forks
I imagine you just oil them on assemly and after that the fork oil will lube them?
