2 Stroke gathering and YOC camping weekend 2014
Indian Curry house! OK so last time me n blackhat were there we found an 'indian' I will be going there on Saturday night who wants to join us, I'm thinking of booking some tables around 8pm is that alright? BTW I'm going on the TTR this time, not 2 strokin
new member dtr 125 2003
Greetings gaz
FJ1200 is puffing!
if you're ehaust valves havent enough clearance I suspect you are in danger of burning the one in question out?
125 dragstar fuel guage ?
have a look at the plate behind your fuel tap, you may see it has OFF / RUN / RES positions ??? Set to OFF every time the bike is not in use The tank holds 11 litres including reserve Set to RUN when you have enough fuel in the tank If the engine starts to splutter / die, set to RES you have 3.4 litres left so get her filled up
Brand spanking new user
Its great to see you gushing with enthusiasm dave, take care riding in London though Yeah those straps often have a metal clip that hooks behind something...?
89 xt350 hot shutdown????
heat can find weaknesses in ignition stator coils, they can open cct when they become hot and re-connect when they cool down. !st thing to check is if it's still sparking when the engine cuts out
my bandit has carbs and a fuel gauge fil
I dont know about the fuel gauge but you should have a 'Reserve' position on the fuel tap...whatever you do ...dont ride around day to day with the tap set to reserve, it's there to give you chance to get filled up with fuel.
xt
I give up! I'm closing this so we dont continue with multple threads about the same issue
HOT V's CRAZY Women
bippo doesnt exist...she's just a dream
relay arm dt 125r
relay arm...whats that Ronnie ?
pls can any one help
perhaps the battery is on it's way out?
1975 DT400 Turn Signal/Brake Light Issues
it's pushed into the brake lever perch isnt it, just prise it out of there and fit the new one....dont see why this has anything to do with the throttle assembly but then again you can see it and I can't
hi
Greetings Ronne, yeah they're good little bikes arent they
HOT V's CRAZY Women
Pay attention boys http://www.youtube.com/watch?v=hKWmFWRVLlU
Dt125 lc mark 1
If it's using the water then perhaps it needs a new head gasket and the head will need to be checked for warpage
hi
Greetings Alf and welcome back to motorcycling
- TTFN
- Haircut
Another new 'un
Phew, good call bakes. Get that test passed fella, you'll enjoy a 650cc far more without a doubt
1982 RD350LC - Stood 20 years
Ooohh nice
Dt125 lc mark 1
the easiest way to test the rings is a compression test in the first instance, if compression is down you would strip down the top end and examine the wear of the rings/bore/piston etc
Dt125 lc mark 1
Its a 2 stroke, if it were a 4 stroke that might be the case
Dt125 lc mark 1
do a compression test chris, the motor could be worn out fella, if you're lucky just new rings will sort it but start with a comp test
Hi I'm chris
Greetings chris, hopefully you'll get the answers you're looking for
