Ybr electrical problems
have a look at you battery terminals to see if they are nice and clean and tight
try using the starter with a: stand down b: stand up notice anything?
Float adjustment?
it all depends on the strength of the spring loaded pin, some are so strong they will support the weight of the float without compressing the spring...however, most arent. Incline the carb so that the tang just touches the pin, not "off the pin"...there will be no gap, it's touching the pin
no kickstart on '79 xs400?
err...is it elec start then?
Float adjustment?
beats me slice, i dunno WTF you're on about mate Perhaps you're having troble making the mental switch of having the carb inverted...if the distance from the flange to the bottom of the float is greater than spec...then there will be too little fuel in the bowl...honest
Float adjustment?
That's it+1 Dont see how it explains a fuel leak though, it will mean not enough fuel in the bowl...not too much fuel!
Short notice TRF charity event teddy bear picnic
he was on an XT660X supermoto john, we did lots of trails en route to Stanage, Dan went straight there by road
Had a great day Dan...Hugh's a great fella and looked after us well. He even threw in some education around Eyam about the significance of the place re- the 'Black Death' and the fate of a local highwayman which was interesting. Only got pictures of the final destination the 'Pole' on Stanage Edge. The Pole is an ancient waymarker, the only surviving one. It marks the route of the path so that when the snows come the drovers can still find their way Sadly the route will not be able to be accessed using motorcycles as of next Wednesday.
Sr125 intermittent ignition fault
yeah it can, find out the required readings and what wire colours they relate to, if theres a black wire one of your meter probes goes to that one
yep thats it Andew, disconnect the plug from the stator and measure the omns at the appropriate connections in the plug to chassis
Great I'll post some pics later
Mid-life crisis (again)
It's Hwan innit? yeah nice intro Joan, enjoy the R6 while you can still do it mate
Down South?
Thought loomies had closed down?
right I'm in, you have a pM
Hey I wouldnt mind doing this, might have to change my plans now
Golden Oldie - actually bald and grey
Greetings grog, never ridden one! check the engine mounts are tight....give up work, you've done your time
Hello fellow weirdos
Greetings scriberman, look forward to seeing your antics with pics
Londoner James here
Greetings James, yeah It's all in the service manual fella, chapter 3 'Periodic maintenace and adjustments' I seem to remember one of our regulars has a manual for sale
Get a Job Young Man !
https://www.facebook.com/video.php?v=10153082023514622
Where to get cheap steel clutch a plates from - ct 175
ahh yes warped plates wont help much
the cutouts are to stop the plates from rattling when the clutch is disengaged How come you're wanting new steel plates then...what's up with yours?
New member from Greater Manchester
Greetings scooby, get them tests passed and buy something bigger mate...just sayin
Yamaha XT600E misfiring and stop .
is the filter gauze clean on the carb float valve seat ?
Yammy Newbie!
dunna see many about, must be hard finding parts ? hopefully you wont need much.
Back to my younger days again
Greetings CP have fun fella
