Wheres England?
- Wheres England?
- Wheres England?
And see that you dont get too rebellious Blackhat250- Hi all
- Snapped my XT125X Front Brake Lever Alread
Hi you could try M&P or MPS, look them up on tinternet, They do hundreds of levers for many bikes, cheap too!- Motorcycle News classic section
Or indeed, mine?- First he chats, THEN he introduces himself
- Tranny issues I think??
Ditto from me. And if i'm honest Im sorry but when i read the title of this post i didn't know WHAT to expect........ I bet this post gets a lot of views...- '82 XS400 loses spark when warm!
Sounds more like a heat problem to me, when the engine gets warm something gets open circuit, not familiar with model though, any ideas Drewpy?- Ignition Help
When you say you have no spark I assume you have the plug removed and you are cranking the engine with the ignition on and the plug securely grounded. Can you get hold of an analog voltmeter? set to 12VDC, Connect the negative lead to battery negative (Or chassis) and connect the positive lead to the coil low tension connector without disconnecting the wire from it, when you crank the engine I think you should see the pointer of the meter 'pulsing'although I must add here that I'm not an expert.- Ignition Help
Hi mate, any sign of life from the battery, lights, horn etc, Is the engine kill switch off, And sorry but have to ask, is there fuel in the tank?- hello everyone
Hello and welcome How about a Bandit? Aagh I mean a fazer- Funny or not, You decide....
My bro in law's one of them, dont tell him I laughed.- For the Americans on this forum!
Youre absolutely right Yamahead, but sometimes you offer an olive branch and just get beaten about the head with it, and so it goes...on.....and on...and on- funny
- stafford show april 26th/27th
Dont know if i can worm out of doing the bathroom, if i can i'll let you know , it would be good to meet up with you and Drewpy- what ever happened to neutral???
Some bikes are just like that, sometimes the oil is too thick, check the right viscisity oil is in there, and sometimes it helps to rock the bike back and forth while trying to select neutral.- honda man turned yamaha
No he's quite entitled to stay here, it's not just your puchbag, and there's nobody better at putting another country down than you Mr P, You could give lessons in it! Go play with your gun.- 1982 400 Maxim Mufflers
hello Jody, Never heard of a maxim 400, but if no one comes up with anything you might have to get a silencer off another bike (might mean a bit of trawling) to fit yours, or adapted to fit, good luck- My 1991 Yamaha FZR1000 left in cold, clutch not working
Dont panic, just bleed the clutch if its a hydraulic one!- Help ! fzr600 no spark
When the stand is up, make sure it activates the switch plunger, If it does'nt, then hold the plunger in with something and try again- Hi chaps..Again !!!!!
- XS360 in the US
I'm only joking, Thats a nice bike you got there, love to see these specials, (more interesting)..- XS360 in the US
- New owner help
Hi Ive got a suzuki bandit and its just the same, two headlights, one for low beam, one for high beam, plus a small running light. I expect that other R6 owners will soon confirm that yours is correct.
