Posts
13,978 -
Joined
Last visited
Days Won
72
Content Type
Profiles
Gallery
Yamaha Racing News.
Media Demo
Store
Collections
Classifieds
Not familiar what is a cw 50 and what year is it?
Does it have a vacuum operated fuel tap?
Its the same on my DT175MX, check without screwing it in.
Bloody maps and ECU's, cant beat a set of points and four carburettors to play with Glad to hear youve got it sorted
Looking good shokz, tell us a bit about it, good buy? whats it need doing to it? using it yet?
Ive heard it said that if you drill two small holes in the oil seal and then screw two self tapping screws into it opposite each other you can then use these screws to pull out the seal., ive not tried it myself though, it depends how tight it is and if it doesnt come out it will no doubt leak more If it works though place the new seal in the freezer for a couple of hours before fitting it as it will shrink and be easier to fit wrap a piece of insulation tape around the spline on the shaft to protect the new seal when fitting grease the outer edge of the new seal and use a socket or piece of tube slightly smaller diameter than the seal to drive the new seal in
Try here, They might export
Given that it takes a certain amount of time to fully burn the fuel / air mixture, the point of ignition has to vary in proportion to engine speed Make some assumptions here just for a guide At tickover speed of 1200 rpm,the ignition advavce is set to 2mm before TDC so assume that all the fuel is burned at TDC But at 8000rpm there will be much less time for the piston to travel from 2mm BTDC to TDC there would not in fact be enough time to burn all the fuel To overcome this, the point of ignition has to be advanced as the revs rise, and this is the reason for advance retard systems Hope this helps
I doubt it Chris, but perhaps you could Ask here
Thats a cynical view of the people here, you probably wont get a reply now.
Open a photobucket account Upload your pics there with each pic you will see four fields Copy the IMG field Paste into the forum
Spotted this at the Barbican in Plymouth this week, the pics dont do it justice, truly awesome workmanship
Yes very impressive
Well done Audie, im with maximuscle, ride safely within your own capabilities and enjoy a great life experience.
I got a CD from ebay, covers various 125/175 250/400 DT's on PDF files
If youre lucky it might just be a broken spring, number 14 on here Shifter You would not have to split the crank case to get this far
The first and easiest thing to do is confifm that the gear lever splines are intact and that the lever is not slipping round on the shaft
Welcome to the forum lotty, sorry to hear that and i hope you soon get a new girlfriend...Now about that DT?
1 (1M1-82590-21-00) WIRE HARNESS ASSEMBLY . . 1 (1M2-82590-21-00) WIRE HARNESS ASSEMBLY . . 1 2 443-82508-21-00 MAIN SWITCH ASSEMBLY . . . 1 3 1M1-82555-00-00 DAMPER, MAIN SWCH 1 . . . . . 1 4 1M1-82556-00-00 DAMPER, STOPPER . . . . . . . . 2 5 90201-05033-00 WASHER, PLATE . . . . . . . . . . . 2 6 92990-05100-00 WASHER, SPRING . . . . . . . . . . 2 7 98503-05025-00 SCREW, PAN HEAD (98501-05025) . . . . . . . . . . . . . 2 8 260-83371-12-00 HORN . . . . . . . . . . . . . . . . . . . 1 9 97013-06012-00 BOLT . . . . . . . . . . . . . . . . . . . . 2 10 92995-06100-00 WASHER, SPRING . . . . . . . . . . 2 11 92901-06600-00 WASHER . . . . . . . . . . . . . . . . . 2 12 1Y8-82310-40-00 IGNITION COIL ASSEMBLY . . . 1 13 98511-06025-00 SCREW PAN HEAD (92501-06025) . . . . . . . . . . . . . 2 14 92995-06100-00 WASHER, SPRING . . . . . . . . . . 2 15 90462-05005-00 CLAMP . . . . . . . . . . . . . . . . . . 1 16 81E-82370-20-00 PLUG CAP ASSEMBLY . . . . . . 1 17 1M1-82530-02-00 STOP SWITCH ASSEMBLY . . . 1 18 BTY-6N63B-10-00 YUASA 6N6-3B-1 (1E6-82110-29) . . . . . . . . . . . . . 1 19 90445-08047-00 HOSE (168-82112-00) . . . . . . . . 1 20 118-82141-09-00 LABEL, BATTERY . . . . . . . . . . 1 21 120-82131-00-00 BAND, BATTERY . . . . . . . . . . . 1 22 1E6-82122-01-00 SEAT, BATTERY . . . . . . . . . . . 1 23 1M1-82115-00-00 WIRE, PLUS LEAD . . . . . . . . . . 1 24 1E6-82150-00-00 FUSE HOLDER ASSEMBLY . . . 1 25 1E6-82151-00-00 FUSE (10A) . . . . . . . . . . . . . . . 2 26 1M1-83350-60-00 FLASHER RELAY ASSEMBLY . 1 CONTINUED ON NEXT FRAME ä ELECTRICAL Ref. Part No. Number Description Qty Remarks E9 DT250D_DT400D
Thing is, what caused it? are the exhausts heating it up? Ive seen insulation wrapped on the pipes somewhere in the past in order to combat this
Oops, should have gone to specsavers , She gets my vote
