Airhead
  1. Airhead replied to azza's topic in Naked
    Hello and welcome azza, awesome 125 you got there, take care of it and on it!
  2. Airhead replied to lifesfantasy's topic in The Bar
    And a big HELLO to you too m8, Oh and also a big WELCOME
  3. Airhead replied to caseyadam's topic in The Bar
    Hello and welcome caseyadam, wow what a steal you got there!
  4. Isnt there a dipstick on the oil filler on this bike?
  5. If you dont know why its not fuel problem then why not eliminate this, the fact that it starts and then runs briefly could suggest va fuel problem. Why not pull off the fuel line and switch to prime to see if theres a good flow...could be just a drip...a partially blocked filter
  6. Hi its important that the fuel tap is eliminated as being the problem, they are usually vacuum operated...does your tap have a 'prime' position?
  7. If im right in thinking its a 4 cylinder, pinpoint the problem cylinders thus: - From stone cold, start the engine and feel all the exhaust header pipes, the ones that stay cold are the problem...Take it from there. You say it will run with the outside plugs removed, you should not do this unless the plugs are in the HT caps and they are grounded, it can damage your electronic ignition, just something i once read...no personal experience of this
  8. Airhead replied to almightyartisan's topic in The Bar
    Hello and welcome from me too
  9. How did you test the timing, with a strobe? Have you solved the problem yet??
  10. DT175MX Wheel Here you go m8, Ive got one of those bikes too! chadkoch1989 Posted Today, 04:06 PM no one wants to help me out? Not many of these around, not many people know the answers
  11. Wheres that then lotty?
  12. Glad you fixed it lotty without too much grief, as for gasket i think you should attempt to buy new, dont recommend joining compounds, they make it too difficult to remove in future, the only place you should use that is on a crankcase split and rebuild Look here
  13. Airhead replied to SRJ999's topic in General
    Another sad loss of a great biking talent. RIP Craig
  14. Hello Drew and welcome
  15. Airhead replied to VO5's topic in The Bar
    Well done V05, now you can talk instead of just 'lurking' eh! Take care now.
  16. Airhead replied to Jamie#9's topic in The Bar
    Its all a matter of confidence norrie, why not get some miles in on quiet roads first, get accustomed to the bike and you will fell more confident, then you will find it much more enjoyable, after this go and get in the city traffic and show command of your bit of the road Take care
  17. On mine (DT175MX) there are numbers 1 to 6 moulded in to the engine casing, why not check to see if yours has?
  18. Airhead replied to curve_hugger's topic in Naked
    Hi and welcome Cat, good luck with your project You might find this place useful Clicky Link
  19. Airhead replied to MEAN 1's topic in The Bar
    Hello MEAN 1, welcome to the forum, nice bike, what mods did you do then?, show us some pics in gallery if you want
  20. Airhead replied to MEAN 1's topic in General
    Ehh, what are you saying? Which one did you join yesterday, this one or that one, that ones got 229 members, this ones got 12,942, but were rarely all on here at the same time
  21. Airhead replied to an2ony's topic in Naked
    Hi an2ony, welcome to the forum
  22. Thats about 5.30am at the mo...I'll be waiting
  23. Undo the locking ring on the cable adjuster on the clutch lever, screw the adjuster in one complete turn (clockwise) and tighten the lock ring again this should give you a little more free play, take it out tomorrow and hopefully it will be ok, have a look at the routing of the cable see if you think it looks right. Let us know how you go on.
