Airhead
  1. My computer cant handle the link...when is it...Sunday?
  2. Good on ya oj
  3. Have a good one drewpy, I'm off to the NEC bike show
  4. It's not an oil pressure light, It's a 2 stroke tank oil level light, comes on in Neutral and if the level in the tank is low...no bother if you're pre-mixing Car oil has additives that might make your clutch slip...bit ironic that eh
  5. its just the plates stuck together. Get the engine hot. Then select 6th gear and with the clutch lever pulled in try pushing the bike it might free them. Plz post q's like this in 'Workshop' Ohh and how bout a little intro in 'New Members' ?
  6. unscrew the plug cap and chop off 10mm of HT lead from the front cyl coil
  7. Its all a bit of a con, NEO sussed it he's sharp that one
  8. Airhead replied to meatloaf's topic in General
    wheres Elvis, wheres Bippo, wheres Cynic, whares DT502001 ????
  9. Airhead replied to captf's topic in General
    haha
  10. you're missing the point, if it had a big chain/cable clearly on view...perhaps they'd have walked on by an alarm might be good too, it all helps if your parking place isnt secure
  11. hmm i'll have to get mine listed
  12. dont buy cheap, got to your yamaha dealer and order the proper parts, they will be high tensile strength and you should fit proper bolts to your brakes, what year is your ybr ? hey I'm sorry to hear about your predicament, thieving bastards, try to get something other than the disk lock, a big cable/chain lock as well ?
  13. Airhead replied to pignapper's topic in Projects
    dont know much about these things but my thought are...does it have a balancer shaft?
  14. Wide Open Throttle
  15. Airhead replied to XR650-R's topic in Yamaha Workshop
    just leave the sparkplug out, it'll all evaporate over a day or two
  16. might not be enough just to wet the key mate but try that first eh?
  17. I do, never had any bother by doing so either
  18. Check your nipples, have you still got two?
  19. Airhead replied to XR650-R's topic in Yamaha Workshop
    That'll be the problem yes it'll suck loads of fuel through because the small drilling in the end has gone
  20. best I can do is ammend your title Mark
  21. Greetings Naomi, you were done there !
  22. Airhead replied to XR650-R's topic in Yamaha Workshop
    tell you what, get a jam jar with a little water in it, take the gearbox breather tube and put it beneath the water level and start the bike, look for bubbles or the water going down...that'll test the RH seal, It's an easy enough test to do and I'm not happy about the smoking just yet but it could be the smoke they all put out when cold...just seemed an awful lot in the vid
  23. Airhead replied to XR650-R's topic in Yamaha Workshop
    john, yeah the tube is shorter but no worries because the vacuum will draw fuel up the tube in the bowl anyway provided the seal around the tube is intact. Now this syringe...How do we know that the rate of descent isnt absolutely normal, I've never heard of anyone using it as a health check tool for an engine? and didnt blackhat say his 250 did the same, dont forget the syringe doesnt hold much fuel in it's small diameter. Cant see anything wrong with this carb, it looks in v good condition to me. What about the smoking, boy does that thing smoke!!! this could cause rough running as I think I said earlier. The RH crank seal may be fubared for all we know...does the smoke smell bad bad bad yuk...or a nice 2t oil smell? Take out the dipstick, can you smell petrol in the oil?
  24. Airhead replied to XR650-R's topic in Yamaha Workshop
    well I never, you'll need one of these then and some gaffer tape
