New member RS200 café racer
looks good though not a bike for using in the rain eh?
Y.O.C. 2018 meet,
All things being well yes I'll be there Paul, so it's not Friday night too this year?
Canadian Newbie
Greetings Adam
Y.O.C. 2018 meet,
races the following week http://www.darleymoor.co.uk/motorcycle_race_fixtures.php
DT175 air leak?
check your cab vent and its tube isn't blocked/kinked or otherwise restricted
Petrol Tank Virago 535
just what I was thinking!
6 volt battery tests
most likely dirty contacts in the ignition switch Simon, if you jumper a feed to the flasher relay brown (at a guess) it will prove that
New member from bevon
next to Aornwall ?
- Tell spring has sproinged
Mixture
sometimes Alan I have seen a small jet type orifice right in the mouth of the carb where the air is sucked in for the mixture screw regulation,,,not sure if your LC has this but they can get a bit blocked with debris from the airbox and need poking clear and blowing through with compressed air. You can see it here right at the bottom of the intake..
New member from Northampton
Greetings Col, wow you've youve got some classic rides there
DT125MX big end bearing
Looks like a very nice clean example Ben
pretty sure theres a place in Liverpool that will rebuild it... http://www.grampianmotors.co.uk/images/Grampian_1.pdf
Greetings and Salutations...
hopefully Mike, wonder if theres any checks you can do regarding the performance of the pump in there?
have you tried brim filling the tank?
yeah stick around Mike, its a bit quiet here lately and good to see a few new members are the carbs gravity fed or pumped
Another Yam fanatic!
like your style mate , greetings
that looks nice Mike, was going to say replace the fuel filter too but wouldn't that fuel be a bit more repetitive and maybe show more when its being given the beans, its an odd one that Greetings by the way question...are the carbs not normally lower down?....could it be connected to fuel levels theres not much fuel head there!
Afternoon from Lincoln
Hi Chris
- Fork oil
Back to black
for some reason I don't see any images !
Hi from Scottish Borders.
Greetings Ian, good luck with it
- Fork oil
1981 Xt250 exhaust muffler
Maybe the exhaust is off another bike but it looks ok on yours to me, the guard you have will be good enough wont it...aren't you happy with it? Blackhat suggested why the bike leans more, it's usually because of wear on the pivot bracket and bolt
Its just the heat shield you are referring to, you have the muffler
