Hi, I'm new on the forum
Welcome to the forum Dana.
- Newbie!
yamaha xs 400
MerryXmas Graham, welcome to the forum.
- FZ 1
- Hello Yamaha Owners Club
- merry christmas!!
125 dragstar crankshaft replace
Hi Simon, that is a job for the professionals not your average enthusiastc home mechanic me thinks!
Welcome Richard, sounds like you got just what you wanted for Xmas
- Howdy
xs500b carbs
Hi its worth asking Here even if they dont list, get in touch and ask, its worked before
how to tell difference between magneto system and battery system
Hi donny, if its a magneto ignition it will spark if you disconnect the ignition switch, it will also have just one wire to the coil i think.
1999 Yamaha DT125R
Looks a real nice bike Jon...enjoy
cast wheel restoration
Hi, lots of people have done it Here
YBR front wheel bearings
Well i was gonna say if you were just replacing bearings you will find the bearing numbers on the old ones, maybe if you have the old wheel you can remove the bearings from that and either use them if they are smooth, or get the numbers off them and get yourself some new ones from a bearings supplier, this would be cheaper than buying them from a dealer i expect. I must add that there is usually a spacer piece between the bearings and you will need to fit that also, if you dont you will damage the hub or bearings and compromise the handling of your bike!
so your new wheel, is a brand spanking new wheel with no bearings in?
Brake problem
so you dont do lateral thinking then, we moved on from his first post when he made a second one! or should we just accept his first post as a statement of fact? after all my back wheel doesnt move much either when the bike's on its side stand
i done it! :D
ERGO is the Euthanasia Research and Guidance Association, so just WHAT are you suggesting there?
Electric start on 1974 dt 125??
A picture might help Open a photobucket account Upload your pics there with each pic you will see four fields Copy the IMG field Paste into the forum
yamaha r125 2009!!!!!!!
Welcome to the forum Q What do you find in a gallery A Pictures Correctamundo, so wheres the pictures since this is the gallery section?
Brake problem
Youve got to do some lateral thinking! If you cant push the bike coz the front brake is on then the back wheel wont turn, so...you 'think' the back brake is jammed on. :banghead:
Brake problem
Eh? Thats weird, you sure youre back axle isn't loose?
Hi All - I'm New Here
Hi and welcome to the forum
- CBT
Riding 50cc bikes on the road.
This is a quote from DVLA website What is a moped? A moped is a motorcycle that has the following features: maximum design speed not exceeding 50 kilometres per hour (km/h) (about 31 miles per hour (mph) an engine capacity no greater than 50 cc it can be moved by pedals, if the moped was first used before 1 September 1977 As you can see, point 3 will not apply as pedals arent fitted anymore, it is a 50cc motorcycle but for some reason people still call them mopeds, it would be better if they didnt IMO
Dont see why not, i dont think the law is bothered what shape the bike is as long as its a 50cc
