Airhead
  1. Airhead replied to Imanupstart's post in a topic in General
    Great stuff, well done...
  2. Airhead replied to hankodan's post in a topic in The Bar
    Fine by me too, I wonder when Yamaha dropped that colour, I now associate them with blue for some strange reason, although the Yellow / Black will live on, I'd put money on it that a Ltd edition Yellow and speedblock livery would boost sales
  3. Airhead replied to hankodan's post in a topic in The Bar
    With a name like 'KingKennyWannabee' how about yellow and black speedblocks?...
  4. Airhead replied to dragstar_125's post in a topic in Yamaha Customs
    6 members are celebrating their birthday today Piston_Ported(47), savior_jack(21), bec(29), Ch4lky(32), Goff(39), attoio(51)
  5. Hi Darren, Before you adjust the mixture screw just check you havent got any leaks between carb to inlet rubber mount and between rubber mount to reed cage. start the bike and warm it up to a steady idle, then while its running spray all around these joints with WD40 and listen for any change in engine noise, a change would indicate a leak, and a leak would mean lean running which can be fatal!!
  6. Airhead replied to wild foamy's post in a topic in The Bar
    haha, that takes me back, used to hold down the lever, give a hand full or revs and let the lever go...great fun on the old step thru's
  7. Ooerr, i didnt read the thread properly, full throttle for 3 - 4 miles, I find that when I do that it doesnt go any faster...just makes more noise!!, as you say the mixture screw is out of the equation at WOT ...so it just cruelty to elderly DT's then
  8. Airhead replied to dragstar_125's post in a topic in Yamaha Customs
    OK I'LL START HAPPY BIRTHDAY TO YOU
  9. Airhead replied to dragstar_125's post in a topic in Yamaha Customs
    I know too, happy birthday from moi as well .xx
  10. Thats right if full chat is also full throttle, but could be full speed on 1/2 throttle on a flat road with a tailwind...worth considering?
  11. Airhead replied to vic-fzr600's post in a topic in The Bar
    Well its a switch so it will be very few Ohms (around two) in one poition with meter set to 200 ohm range, and very high or infinite ohms in the other position with meter on 20 KOhmm range...at a guess, i've never tried it.
  12. Airhead replied to PeterC's post in a topic in Forum Help
    I know the one you mean, it showed it on a red bike (Honda) at the end of the topic!! I'll try to find it later.
  13. Airhead replied to vic-fzr600's post in a topic in The Bar
    Thats right i thought it was. Am still intrugued by the addiotional post though about the clutch, I would check the clutch switch with a multimeter
  14. Airhead replied to vic-fzr600's post in a topic in The Bar
    has it got CV carbs? could be a split in one of the diaphragms?
  15. Airhead replied to PeterC's post in a topic in Forum Help
    Hi peter, have you seen this Here I am planning to do mine but dont know if i'll ever get around to it.
  16. Youre right, this expander ring is only supplied with genuine yamaha rings, thats why i would say re-use it, if you cant...then thats that! i dunno what its purpose is but obviously Yamaha thought it was a good idea. so you havent got an "oil scraper" ring, just two rings...thats good, what are you going to do to prevent a recurrance of the last disaster?
  17. How many grooves were in your old piston, there should be only two. Are you referring to the expander ring that sits under the second ring; If so re-use the old one.
  18. Airhead replied to gabby's post in a topic in The Bar
    wondered where you'd gone, ...welcome back!
  19. Airhead replied to Daiv's post in a topic in The Bar
    Great stuff Daiv, dont forget to pop back now and again, after all, you DONT even have to have a bike really, see you later mate...
  20. Airhead replied to austin's post in a topic in Classics
    I'm surprised its the same with the choke on though, perhaps you are losing your spark when you load the engine, try a new plug, or check the electrode gap at least, best of all use a plug checker to see the spark Here
  21. so does the crankcase seal run on a shoulder on this gear, and now you have a groove in this shoulder?...not familiar
  22. Hi pots, dont like the sound of the groove you describe, the only real way is to pressure test your engine (and i dont mean a compression test), I suspect your transmission oil will smell of petrol in due course. there is a dedicated rdlc forum, our Mervin will hopefully guide you there. ...Paul
  23. Airhead replied to pilninggas's post in a topic in Yamabyss
    one of those being UK PLC !!! And it seems that quite a number are abusing their expenses accounts, its no wonder that people are losing the will to vote.
  24. Airhead replied to austin's post in a topic in Naked
    its time to strip & clean the carb, check for water in the float bowl or blockage in the main jet, failing that do a general strip and clean routine using carb cleaner (avoid this on rubber parts) and compressed air. This is a useful read Here
  25. Airhead replied to austin's post in a topic in Naked
    First check for a good strong flow of fuel from the petcock.
