Airhead
  1. You need to check for bad connections, are you in the habit of checking battery levels and topping up accordingly?, maybe the battery is on its way out, will it operate the horn?, I must admit that indicators on 6v bikes aren't that good
  2. Youre gonna need some sort of a rubber bung to stop off the end of your pipe....wine cork? i dunno ! Dont cut any corners with the caustic soda, wear goggles or better still a face mask and gloves and take care!!! its nasty stuff. if I had room in my garage there would be one of those little beaut's in there too, now how about a picture?
  3. Hi Vincent, theres a pinned topic on DT125 tuning and mods in the 'Workshop' forum.
  4. Glad you got it sorted, I overlooked the expansion of the oil as the motor warms up, thanks for pointing this out Cynic...so its not a major problem after all and no need to split the motor...result, always did seem far fetched though for such a young bike surprised it even needed a rebore, maybe a new set of rings would have done eh?
  5. Airhead replied to Fulmar's topic in The Bar
    Welcome fulmar You sold the LC .WHAAAAT
  6. How is your problem similar?
  7. How bad? any leak is bad you need 100% sealing, besides that test is done with the bike stationary under no load conditions, its likely to be a worse result with the throttle open and the engine working the problem can also be masked as the engine sucks in oil under negative pressure pulses in other words if the engine sucks in a bubbles worth of oil then thats a bubble you wont see.
  8. Welcome to the forum winklepie. you need to speak to member 'Gas up - Lets go!'
  9. Remove the bleeder bolt (Plug) from the top of the pump. With the engine shut off open the throttle fully and rotate the white plastic plate in the direction of the arrow on the plate. Continue until air bubbles cease to come out of the bleed hole. Re- install the bleed screw ...job done.
  10. Did he really forget to mark the cup?????
  11. Airhead posted a topic in The Bar
    Coming home from work tonight when suddenly progress came to a standstill at Mottram for a while, evantually get moving and 600 yards up the road theres a bike on its side and the rider lying on a driveway (people were attending). Hope he's ok and all you commuters take care especially now the journeys are in darkness.
  12. The OG crankcase compression test would be good I know, some things dont seem to add up...like the age of the bike, and the mileage, piston slap at < 5000 miles
  13. Forgot to say, it may suck the water up or it may blow bubbles ( it should do neither) so draw a line and whip the tube out if the level falls, you dont want water in your gearbox, on this point use a narrow vessel rather than a jar...a test tube for example...if the level falls you will see it much quicker
  14. Thanks for the clarification, do the tube test now, unfortunately it looks like an engine out and full strip and seals replaced at this stage.
  15. I can only assume that 'pop the clutch' means bump starting to us this side well pop the clutch then remove the plugs, are they wet with fuel? A compression test might be appropriate too! or failing this,,,squirt some oil into each cylinder and try again to bump start the bike, this should improve the compression if its low and can sometimes help start a worn engine
  16. Hmmm i would be somewhat pissed off if my 02 bike with only low mileage was this bad!!! However you did state the level of oil drops so it does look like youre burning the stuff, To test the RH seal (clutch side) on my bike i could put the gearbox breather tube into a jar of water and run / rev the engine whilst watching for bubbles, this is a dead giveaway wor a sha**ged seal, does yours have a breather tube that you too could try this?
  17. I think if its used on the road youre gonna have to fix it, what year is it? if its an old bike the seals hay have become hard and worn. is it watercooled and are you sure that this white smoke is not just steam in the cold air that we now have because that's also white too! until the bike has warmed up to temp...all things to bear in mind
  18. sounds like the clutch side seal has gone, although both sides would be replaced at the same time. Sometimes you can smell fuel in the gearbox oil too. is this bike used on the road or just a field bike? if its a field bike it would have to be bad to warrant a engine strip, but a road bike will have to be right or you will attract unwanted attention and will no doubt have trouble at MOT time (possibly?) Its a big job if you have to strip and part the cases so it might be worth doing the bearings too.
  19. Airhead replied to drewpy's topic in Yamabyss
    my kind of girl
  20. so you tried starter fluid...............and?
  21. This 'gauge' you mention, is it the glass window type that is common to many bikes? the usual way is to have the bike on the centre stand on a level surface, if no centre stand is fitted then get someone to sit on the bike for you whilst you look. Also sometimes the oil quantity is written in the casting near to the fill hole. or it should be in the owners manual. ...Paul
  22. Airhead replied to SRJ999's topic in Classics
    Sorry to hear youve had such a bad year SRJ, wondered what happened to you and glad to see you on the forum again hope things buck up for you soon Dunno anything about the bike in question though, is it near enough and have you got the means to collect it? a close inspection of the chain and sprockets and tyres would be nice (or ask the seller) if he says they are worn you need to factor that in too. As for the ebay sale, it seems cheap but he's got a reserve on it so its not likely to go for £100 PS...the red wheels look naff IMO
  23. Welcome crash, lots of expertise here http://www.yamaha-xt500.com/phpBB/portal.php ...Paul
  24. This statement suggests you have run onto reserve This also kinda does...until you say theres plenty gas in there or it may have a blocked mesh screen on the longest tube from the petcock inside the gas tank.
  25. Q1...Use a good quality adjustable spanner then Q2...As with all Yamahas the right side mirror has a left hand thread. This is because should you fall off on the right side the mirror arm wont shear off in the thread...it will just slacken slightly...(least thats my theory)
