dt125 overfuelling(?) problem
One vulnerable area is where the HT cap screws on to the lead, if you have some spare, unscrew it and cut off around 20mm of the lead for a 'fresh' connection.
XT350 main shaft play
The link doesnt work. PM sent
- Cod & chips twice please
xs400 flat tracker project
Very nice Drewpy did you get the scarf and goggles to go with it ?
2006 yz85 BW
Welcome si, its a competition 2 stroke MX bike yes? is it seized, what have you dome so far? i'm wondering if it has a special plated barrel, maybe having a word with professional re-borers would be wise ...try PJME Your boy is so lucky to get this ...Paul
My first big bike problem ( part 2 ) Plz Help!!
Bike looks nice and clean, sounded ok when rev'd too. I think the tickover (idle) seems a bit low I would have expected around 1100 rpm for this, that would mean adjusting just one screw which should be fairly prominent but I cant tell you more as I am not experienced with it.
DTR power valve compared with DTRE power valve
Ohh ok veZ i get it Any way I still dont agree, the way i see it in that case is that exhaust port is fully open all the time but then just offers a restriction in the exhaust. I might believe it though if each and every DTRE DTX does the same, that would be too much of a co-incidence.
The thing is you need a special vacuum gauge and tubing to do it, not to mention some skill or experience, so it looks like you may just have to pay it or find someone who will do it for less...shop around dont just take the first offer eh?
I dont buy that VeZ, your PV is fully open with the pulley slot and drilled hole aligned just like mine, it even settles down to the same position at idle...ie a little clockwise from fully open. but then goes further clockwise with increasing revs does it not?
DT 125 R cutting out problem
if you can...measure the resistance of the ignition coil both primary (LT) and secondary (HT) sides and make a note of the readings. Then when it cuts out repeat the test to see if it has gone open circuit. Repeat for pulse coil.
I wouldnt be happy if it were mine, no matter if i had seen others on you tube vids. The PV is tied in with CDI and servo so either one of them is faulty, or the wire thing will put it right,
Overheating DT125R Help pls
you are supposed to torque them down, then torque them again later i think..was this done ? Could also be a faulty seal somewhere which stops the pressurisation, radiator cap seal possibly ?
1975 Yam DT125B
I would think the brushes are ok if the starter motor is doing its job...ie turning the engine. Check your spark plug gap is not too big. Ohh and you forgot to say hello ...Paul
I think your head gasket has gone, have you torqued down the head nuts or re-checked them. If it is this youll be pissed off when you lose your new coolant.
Yamaha DTR 125 Cutting Out When Pulling Off
DONT!!! Leave it bypassed, that is very dangerous...get a new, or new used switch for your own sake or anyone you sell the bike to later.
My guess is either spark plug, ignition coil or pulser coil are faulty. Try a new plug first as its cheap and easy.
Hi and welcome to the forum Sounds like your sidestand switch is faulty or has a bad connection.
help finding a bike
Nice one Drewpy Vehicle details cannot be found so thats not good news, still it has to be worth a fiver to pursue further...no choice really. Only a slim chance it survived though i expect you know that.
help finding a bike
I'm sure there was a way of seeing if a vehicle is taxed, or indeed when the tax was due (date of liability). But i'm damned if I can find it now. Although this wont tell you where the bike is now it will give you some clue to its last use. Also print this off and enclose the fee, DVLA may or may not co-operate Request by an individual for information about a vehicle Also a good site to ask is Aircooled RD Forum Good bunch of lads on there. Good luck...Paul
sr125 top end rebuild
Dont you have any friends / family in GB who can post them to you?
Cleaning aluminium alloy
Nice one for getting mobile again Steve. its not a smart condition bike but naturally you want to improve it. if it were me I would clean up the affected parts and simply paint them. Dremel tpe tools have lots of brushes and abrasives available, obviously along withe wire brushes and wet / dry paper. i see Darren (gas up...) has recommended plasti kote paint, I can vouch for that with regard to their BBQ paint for use on black painted exhaust. Available cheaply from wilkinsons.
Yamaha DT125R Cylinder Replacement
2 - 3mm deep! You sure Tobe? dont say its that deep unless you are certain. That sounds awfully deep, more than the average score.
Retro-spot,,,,,,,,,,,,
He's no match for a proper electrician.
Big power change at approx 5000 revs, normal?
Too right Reecy, you enjoy it fella, not many people these days experiencing the joys of a 2 stroke motor. Oh and if you look after it...in ten years time it will be as old as mine (is now)
Ooogh a power band, lucky git...enjoy
