TY175 Information
If you go to the workshop section and see if there are any parts manuals for the TY's, then you can count the cogs on the gearbox layout
DT50 - why cant i go up hills (even very small ones)
So you said you hoped it was not the actual holes the studs go into Thats when I thought that maybe as you tightened the nut on the head you would either see the stud pulling up through the nut OR the whole lot would just spin round. Either way this is very bad news and a new thread insert would have to be fitted into the crank case. Like I said it's not a job for an amateur and would mean buying a special insert kit and drill as well. do the threads in the case look good or have they gone?
No Ryan it's not rideable like that you will do it no good. It sounds like it needs new rings and who knows? maybe even a rebore, the black marks are signs of 'Blowby', this happens with worn piston rings or a worn bore. the gaskets will need replacing, be sure not to get any debris into the crank case when removing all traces of the old one, stuff a rag in there while you clean it up. I am concerned about this rounding...It isnt pulling the stud out of the case is it? I hope not as it would need a thread insert which is no job for an amateur,
yamaha dt125
No they are great bike but they are an aerodynamic fail when it comes to going gteat speeds, They arent built for speed although a good one will do 70 / 80 flat out. There are other bikes that have a better frontage for fast speeds.
Cardboard Dave is this how you did 95?
Hope you wont be too disappointed mate when you clean off some of the rust and find......
oil light problems!
If that's what YOU do it's fine by me
RXS100 two stoke oil level not going down
1: I cant see that being right about using a tank of 2T for two tanks of fuel...no way. On the RXS can you see the level of 2T in the tank...mark it with the bike upright and monitor it. smoke from the exhaust would be a good sign too.
yamaha dt125
I'll put money on it it's a DTR
81 DT 175, idle and starting question
Adjust the throttle stop screw to achieve an idle. Note the position of the air mixture screw and turn it clockwise until it gently seats, it should be around 1 and 1/2 turns out from this position, Now...did moving the mixture screw affect the engine speed at all, it should really get a bit lumpy as you screw this in. Edit: In another thread you said the 'o' ring was missing from the mixture screw...so did you replace it? you didnt say!
My TZR splutters and dies !
Was it good before the air filter clean? What type of air filter is it? How did you clean it? Did you oil it before re-fitting? You say it splutters with the choke off...is this with a cold engine of a warm engine?..
oil light problems!
It should be ON constantly when neutral is selected, this is a bulb check function so you dont get caught out with a blown bulb. When in gear if it is ON at any point...top up the 2 stroke oil and it will dissappear. It has nothing to do with gearbox oil, that's just a dipstick check.
does you carb float bowl have a drain screw? Try draining it... it might have some water in it.
New member... So... Hello :-)
Good intro moggy, if you do learn anything useful about riding bikes be sure to let me know
Deleteing gallery images
OK Garfield, it's gone Nice little bike, welcom to the forums.
DT175 no power
Could be any number of reasons, what other forum are you getting help from? Myself I would meticulously clean the carb first and blow through all the little passages in the carb body with compressed air. Re-assemble and set the float height and mixture screw. If that didnt cure it, then I would take meter readings of my magneto coils and ignition coil to see if they are out of spec. How many wires connect to the CDI ?
GT80b???
sounds like a plan, or more likely to have liquid gasket, try that...try anything !! Clean off all traces of oil first.
DT175 no power
I havent heard of this washer you speak of, however this is what I found in my DT175 header pipe. Theres no way it is affecting your performance as badly as you report though.
DT175 no power
I dont suppose you have any pictures of that?
DT175 no power
What is the air filter like...does it need a clean? Not sure about the carb on the DT175E ...whether or not the needle is adjustable fot height or not like the UK bikes were What do you mean by gutted the exhaust?
Trying to sort historic status Oct 1972 RD350A
Hi smokin, I'm not sure what the procedure is but maybe our mervin will know, he will no doubt direct you to the aircooledrd forum http://www.aircooledrdclub.org.uk/forum/active_topics.asp or of course the VJMC WILL be able to help ...Paul
big kev's choker.
or you could ring Steve at motocarb, he may have a plunger...worth a try. Tip get it sent round to your works so the wife doesnt know, I get stuff sent all over the place
GT80b???
on my 175 there is a seal retainer plate screwed inti the case to stop that happening
big kev's choker.
No mate its a while since I saw mine, I think theres some kind of stainless springy thing that falls into a groove but i'm not sure...I expect the sides of the groove are worn down so replacement would be best. keep on using the clip in the short term. Who's to say you WILL buy those, for all you know there is alraedy a £70 bid on them worth a go though at the death
big kev's choker.
http://cgi.ebay.co.uk/RD-350-LC-RD350LC-RD-350LC-4L1-RD-250LC-CARBS-MINT-/150492977249
spark plug is wet with oil
Again...so you havent used it all year then? could be that the crank case has filled with oil possibly through the clutch side oil seal
