Airhead
  1. Airhead replied to webi's topic in The Bar
    webi does this bike have points and a condensor (capacitor) ?
  2. Airhead replied to Airhead's topic in Yamaha Gallery
    It is mate, at one time they were available in black or chrome. Only seem to see chrome ones these days.
  3. I'm confused, is the switch now back in service? The Black/White is the engine kill when it is connected to ground. Withe the key OFF this would be connected to ground and the spark would be lost. If the key switch is not working disconnect this wire and spark should work. Then connect it via another switch to ground if you want an engine kill
  4. Sorry Drewps I didnt
  5. Hi and welcome to another retro DT fan so are you saying the engine races but the throttle slide is closed?, you have not put the slide in the wrong way round have you? The cutaway should face the airbox.
  6. Airhead replied to Cynic's topic in Yamaha Gallery
    Nice one Jason, Good to see a proper pic of the DT, is it road legal now then?
  7. Airhead replied to newtobikes's topic in The Bar
    I've got two DT's mate, dunno owt about XV's though,
  8. Oohh I thought yours was a later one, ( its the square swinger that throws me), dont get me wrong mine isnt bad but somehow I dont think its good enough. I think i'll connect a strobe and see if the advance is working first job. I have a 6 wire CDI and a backplate for the 6 wire CDI version and a mag rotor too for that version. The whole backplate needs re-wiring though so it will give me something to tinker with.
  9. Airhead replied to newtobikes's topic in The Bar
    Welcome to the forum
  10. Your motor sounds to be real sweet now Jason, "shoots round to 10K", mine wont do that no way..I'm considering converting it to a 6 wire CDI now as a winter project. The 6 wire was evolved from my 7 wire two coil set-up as you know. I am thinking it must be a better set up so am going to do it. How did the MOT go and the piccies?
  11. Ouch! is the ebay stuff new or used?
  12. Airhead replied to up.yours's topic in The Bar
    Haha, dont mess with Ogri
  13. I went, billy no mates but still had a good day, loads of cruiser and Harley types there but in amongs them were some real gems, like the guy on a Gilera 50 touring I was chatting to. Ooh and a brace of aircooled RD's and a very nice 1966 YDS3. Ooh and a lovely DT175 with a new tank cover on
  14. Hi O_M. When slowing for lights I go down down down but only to second, then just before the bike stops snick it into neutral, It's easier on the clutch and stops any tendency for the bike to pull a little for example if the engine was cold and the oil thick. Well thats what I do but nobodys watching me As the running in goes it sounds like you know what youre doing and the engine is easy so carry on with it. Tyres I dunno, try avoid the worst of the ruts and check your pressures are good.
  15. I would try to eliminate the oil pump as the culprit. To do this just unfasten the small oil line from the carb spigot and block off the spigot with your finger, does this lower the idle? To bleed it just fill the oil tank up then remove the small screw with a gasket under it that is at the top of the oil pump. Let the oil run until any bubbles stop. There is also a 'Priming' operation to be done, when the engine is running hold the pump pulley fully open for around 30 seconds to allow maximum stroke and push the oil through faster.
  16. Throwovers will fit loadsa bikes
  17. In the Honda book? I hope this is a typo! In the Yamaha book it says 0.75 Litres at oil change, anyway did you check it in the window after the oil change. If I were you I would top it up until you see oil but you have to run and stop the engine and have the bike upright to check the oil window. It might be worth having a look in the radiator too, you said a grey colour...when the water pump seal good you get a milky colour. As for not starting I dunno, did it run out of fuel?
  18. Sad to see bike shops closing, thats where I bought my Bandit from
  19. Airhead replied to spydey98's topic in Yamaha Workshop
    Baffled yes but I still think it's transmission oil. I would replace that seal anyway and stick it in place as has been mentioned previously, After all a seal is cheap and your'e an expert now with this bike and it's seal. Incidentally is it still on pumped two stroke oil? is the seal in the pump ok mine popped out once and emptied the contents of my two stroke oil into the clutch casing!
  20. Airhead replied to Exitpest's topic in General
    3 years to say hello What!!! are you shy Welcome exitpest
  21. Airhead replied to spydey98's topic in Yamaha Workshop
    No temp gauge Pat, It's an old fashioned aircooled jobbie like my DT175
  22. Airhead replied to spydey98's topic in Yamaha Workshop
    pressurised with the exhaust blocked? If baffled, white smoke is transmission oil being burned. On the one hand you have white smoke and on the other you say the seal is good. i'm not familiar with the bike in question though. How else can transmission oil be burned? Unless the crank bearing has play in it and when running the seal cannot keep up with the movement.
