Airhead
  1. doesnt make sense does it so thats why I think it may have something to do with the pilot jet/air jet stuff, your bike is standard with a 160 so it should be happy with a 170 with the Gianelli. Looks like you have been trying to solve a carb issue with jet and needle changes when the issue is something other than jet or needle position. Also have you checked you have the right needle in it. If you cant sort it why not try your spare 3u500 carb I cleaned it up before sending it back to you
  2. why would going from a 160 to a 170 mean it wont run at all, thats not right. It should run with no main jet at all fitted shouldnt it? of course it would be drowned out at WOT without a mj but it shoud still run ok at up to around 3/4 throttle. Would it be worth checking your air jet isnt blocked.
  3. Airhead replied to Wullie's topic in Forum Help
    yes you can but its tedious and slow, so I do it before uploading.
  4. God its freezing, has he got heated grips, thermals, a hip flask...or is he just mad
  5. What makes you thing it goes from rich to lean Jason, I doubt that and would think it goes from rich to richer. If it was going lean at large throttle openings the only evidence you would have is a plug chop...I doubt you would know from performance until it holed a piston. But you would certainly notice poor performance by being rich. I have a gianelli on mine at the moment and it seems ok with a 140 instead of 130 (early airbox taken into consideration)
  6. Airhead replied to Wullie's topic in Forum Help
    I use Paint.net
  7. "Its ok dear...I'll do the shopping from now on"
  8. I know what a pulse is and for that matter a jet too, but whats a 'pulse jet' whats it for?
  9. Airhead replied to Emzed's topic in The Bar
    Good to hear from you again EmZee, specially good as you got the bike running and legal. Thanks for the update
  10. Aaah so barky was right , so congratulations Pat and mrs Pat, you kept that quiet
  11. Hey barky it was for his brother wasnt it?....Psst do you think he had designs on it anyway, about that gonad-gel technological seat
  12. Yeah thats a nice looking bike,...There will be others
  13. Pat can you find it on your browser history?
  14. Good intro Jack and welcome
  15. I have no idea Pat but I would be very happy with it for £1300 even more, sounds mint
  16. sorry wullie I dont, ask redrose
  17. no you cant just swap the plug (HT) wires, I meant swap them both entirely..ie substitute one for the other.however if it is not always the same pair of cylinders it may be something else.
  18. could be a broken wire or connection too, try wiggling the wires around near the generator, keyswitch and at various places around the loom that may be relevant
  19. How about you swap the two coils for each other, then see if the problem appears on the other 2 cylinders, this will point confirm if it's the coil.
  20. If you pull out the cable from the speedo does it turn as you spin the wheel? and also if you grasp it between your fingers you should not be able to prevent it from spinning as the wheel turns. Speedos are not meant to be messed with
  21. ok but if you get ripped off dont blame us.
  22. but you said the valve works? so the motor is fine and still connected then
  23. Yeah sure Paul try These Guys
  24. I prefer funny vids myself
