Airhead
  1. might call in and see you on my way home from FS1E rally, I'll ring you if I go
  2. clean the steel plates with some scotchbrite,, just wipe the friction plates, brush oil on them when re-assembling. Take note that the little 'pips' on the edge of the steel plates are 72 degrees from each other 360 degs / 5 plates = 72 degrees. This will prevent unnecessary vibration
  3. Airhead replied to drewpy's topic in The Bar
    Nice one foamy
  4. you'll have to wind up the preload to max and suck it and see, aint a skinny 17 year old any more ;O
  5. yeah I'm going john but I need to just sort my TT out first, not ridden anything yet this year ......ex biker
  6. Wow David you are having fun eh? Looks to me like you just about tried everything...one thing springs to mind though..what silencer are you using? is it aftermarket? can it be stripped and cleaned / re-packed etc? I'm wondering if there could be some carbon build up / blockage in there Neddle jet 4JC? a typo?, 4J6 I know from experience that silencer packing too tight or old and crusty will badly affect performance
  7. Greetings eden1 your avatar needs to be small, resize to 200 pix if I remember correcly
  8. Its ancient, saw it years ago
  9. Greetings Richard and welcome back fella, nice little intro BTW
  10. It means ridden hard...not treated gently
  11. 4th - 5th isnt it john, I'll be there on 3rd
  12. red - red brn - brn is a dead cert, not sure about the others
  13. this is normal for many bikes with carbs after a winter layoff, It often happens to bikes that aren't used regularly, get them warmed up properly and play around with the throttle position and choke until you can coax them into life
  14. Barry PM me your email address
  15. Greetings Don, yeah join in you're very
  16. yeah, I upload mine to photobucket and then from there to here by copying and pasting the IMG tag
  17. leccy start? a tough bike to choose for a project I'd think
  18. yeah you need a new carb float valve (and seating gasket), however you should be able to start it if you open the fuel tap for just long enough to get fuel into the carb and then close it again?
  19. Thanks Tommy it's right nice of you to see something and think of me However no matter how long I looked and thought about this I couldn't really see why? Perhaps the answer is staring me in in the face all the time... It's a dodgy old swinger? !!! ya cheeky git Tommy I'm hurt I tell you...hurt!!
  20. Airhead replied to Callyspoy's topic in Projects
    well done it looks great but somethings missing?
  21. Greetings Keith, yeah theres lots of DTMX knowledge in here if you need some help yeah lets see some pics
  22. stators are stationary luke, rotors rotate...the clue's in the name
  23. the top of the piston always measures less than the bottom ., because the top gets hottest and it's to allow for expansion. To check piston you should measure it at the bottom and compare to Yamaha specifications in the workshop manual
