78' dt125 clutch issues
Drain it to the correct level, with that bike you use the dipstick without screwing it down to check the level. If your'e careful you will be able to drain just some rather than all the oil by holding the drain plug up against the hole as you unscrew it until some has drained...if you see what i mean. It seems an odd question to me...to know something is wrong and then ask what ill effect it will have...just correct it I say.
XT 125 X Dash up in smoke
I would check the voltage regulator is functioning and also the battery fuse is intact. I dont know a jot about digital dashes but I assume it has had a massive over voltage to do this, so thats why I would check these things ...Paul
YAMAHA DT175
are you in USA? 2k4 is common in europe, mine is a 2k4. Not sure about the tuning though? ex works what? it's just a trail bike...lovely as it is it's no YZ...I dont understand
Its an odd one, assuming you rebuilt and adjusted the clutch correctly... Have you had the primary gear off, replaced with key in situ?
Saying Hello
Greetings lloyd
Finally its took since July!
just listen out for any unusual screeching sounds from the back of the bike
Hello All!!
Greetings Bazz
- Rear Rack
Hello!
I know Liam, read my post above I edited it
Hello!
Liam post a link to the ebay clocks you bid on, i would like to see them Edit I saw them. Mine are different for a later model, The clocks look very slightly different amd they just have one 9 pin plug on them. Be aware of this...what does your loom have? dont buy later ones from your mate if they wont fit. as a clue the temperature gauge has a white/red band on mine. That early one has a green/red band Anyway I think we have just about wore out this hello post now so start something in another more appropriate place if you will
- Rear Rack
Hey :)
I doubt you will get a two stroke, dont blame you for wanting one though. you may have to buy an old one but will probably find one hard to come by.
Hello!
he's a handy mate to have, and the father in law runs an insurance company, some people have all the luck
Hey :)
Yamaha make some excellent enduro bikes WR250 and better still WR450 http://www.google.co.uk/images?rlz=1T4GGLL_enGB401GB402&q=yamaha+wr450&um=1&ie=UTF-8&source=univ&ei=6lwzTYThK8q6jAeoyPTGCg&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CEUQsAQwAw&biw=1003&bih=448
Hey :)
Ha welcome Dean, you make that XT look small...you sure that's not a pit bike too?
Hello!
yes but for all you know the winner could have bid a lot more than £43, ebay bids in increments and at that figure it bids in £1.00 increments, hence you were beaten by £1. I know these things' i've spent millions on ebay What mileage was on the clocks you bid for, was it both clocks and the mounting bracket? BTW my DTR speedo cost me £45 plus post just for the speedo. It was cheap at that though for a NOS one However...i do happen to have a full clockset with only 9000 miles (miles is MUCH better than Km's in UK)many of the ebay ones are Km's and the seller dont always say so, you have to look at the photo or ask. I paid last year £41.17 for this, you can have it for that plus postage if you want it or it will be ebayed. I bought this because my bike had a Km clock on it but never used it because the NOS one turned up and as my bike had done no miles I fitted that one
- A gottle of gear
Nice to meet you
welcome to the forum Thanasis.
Bikers !
For me it was a natural progression from pushbikes at the age of around 13 I had just about done everything I could with them and so I wanted to learn about engines. I got books from the school library and began to study the suck squeeze bang blow of the ICE. Got my first bike a mobylette moped for 50p with no carb or exhaust. Managed to source a carb and even found an old frame that looked better, made an exhaust from part of a chrome racer style pushbike handlebar. had heaps of fun on that thing and sold it for around £8.00. Many other field bikes followed and the best of them all was my works triumph trials cub which sadly got abused and by the time it needed doing up i never seemed to find the time, thats my biggest regret. The points made by Vez are true to all of us, as a commuter they cant be beaten and the cammeraderie between true bikers is fantastic. Look we are still making friends even now all those years later. Hope I'm still doing it in another ten years
- You want a lighter bike ?
- OMFG
heyy am new :D
why have you started a new user name unpronounceable as it is? That is against forum rules bella9 I would like you to stop serial posting about your bike and keep all the info in one thread, I said as much in one of your posts...you read it I know, then decided to not only start new posts all over again but under some stupid user id Explain yourself!
Dt175 Original tyres
I wonder if they are the ones Yambits sell http://cgi.ebay.co.uk/YAMAHA-DT125E-DT125-E-2-75-X-21-FRONT-TYRE-/230427823533?pt=UK_Motorcycle_Parts&hash=item35a6918dad
Help, leaky TDR tank
Bummer thats bad luck Jason. I have never had to fix a leak but I bet Mervin knows of a good cure. I had one on my DTMX many many moons ago but I bought a new tank because I didnt know about fixing them back then.
Hello.
Could it be that they are merely referring to the bearing that is located by the 5th gear pinion and not actually the gear itself? assuming of course it is a 5 gear bike.
