DT125R 2003 with no clocks
Here you are John
I'm Back, Sorta
Wow thats a shock, glad to hear youre on the mend mate, so thats the end of motorcycle for you then?
hi
the seller wont know the part number, but granbys or fowlers will and they can compare for you if they can be bothered, ask them nicely and tell them youre in a fix.
hi
Yamaha dealers...what did they say, I ask again is it discontinued or can't they be bothered? Try Granbys or Fowlers and find out if it's discontinued or not If it is discontinued ask then if they will do you a favour and compare part numbers between yours and that earlier version, they can only refuse but \i dont think they will if its discontinued and youre stuck.
DT 175 MX Engine Rebuild
Hey Phil try your locker at work Buy three more batterys and charge all four with this
yes mate both mechanical cable drives, tacho is obviously from engine. There is a drive unit on the front wheel. Will post some more pics tomorrow if you want...off to bed now
hello everyone
Greetings John the scouser Look forward to seeing the progress of the DTR ...Paul
hello everyone
Read all about it. http://www.yamahaclub.com/forums/index.php?app=subscriptions
Speedo drive is off the front wheel An intro in new members?
The 8 Ball Diner
Yep nice place, should do well.
Fully Restored DT360A
Another top notch job Mark
New Member, DT100E
Greetings wff.. Roll on the resto thread, whereabouts are you then? ...Paul
radiator cap
overheating on a DTR? Thats often a head gasket leak, there are lots of cheap pattern gaskets around and if they are fitted dry they dont last long...been there, got the T shirt
hello everyone
Greetings again Giz, your memory must be as bad as mine lol
1974 dt250a
morning gordo must say i'm a bit puzzled as to why it would make this noise "with the engine turning over in neutral" because the shaft you are questioning is stationary at that time? You need to isolate where its coming from I suppose. is it from the crank or is it from the transmission shafts...or the primary drive gearing? do the obvious like testing for play best you can. take off the primary drive crank gear and run the crank round by hand to check for noise etc. Spin the clutch basket checking for noise again If you really do have to split it you may have to put the primary drive gear back on and peg the con rod to enable the clutch boss to be undone, although it's better to have a proper clutch holding tool of course. (I know...unlikely for one of these old girls)
Virago 125 starting problems
DT 175 MX Rebuild/Electrics
Call me Paul then Early 125's had points later ones had CDI One of the Haynes manuals is not so good, it's the one with an orange front cover border, if you look at the ig switch it shows as 4 wire only which is plain wrong as we have positions 1 2 and 3 withe key. Cynic put me onto a better manual wich also shows the later version wiring diagram.. it has a brown border and a twinshock picture on the front cover...ISBN 1 85010 300 3
Hi
Seems that it hasnt quite left you Take care
Classic DT 125
No picture mark and this forum is for intros . Thanks
You ok Phil
- New Member
New rider saying hello
Greetings captain beeky...or is it captain slow Dont forget the piercings too mate.
Fat tyres
and this is the new members forum Hello its for intro's, I notice you didnt
Yamaha SR 125 compatible head light?
Wemoto M&P ?
Hi
Greetings Great bikes DT's...Take care on her.
