Airhead
Joined
Last visited
Currently
Viewing Forum: Dual Sport, Offroad Bikes
dtr engine out
Hey jon, heres a good place to post about a DTR not starting, the clue is in the title http://www.yamahaclub.com/forums/topic/25757-dtr-not-starting/page__p__144774__fromsearch__1#entry144774
DT125R Hyper acceleration!
turn it clockwise a bit, try about 10 degrees at a time and test it out until youte happy, max about 30 degrees at a guess. Can you work out a way of fixing it in the new position? is the pulley on there? and is it fixed somehow at present?
dtr engine out
Have you ever had it running jon? why did you buy it ?
My new steed TTR600RE
Ta NEV I'll look into that Thanks Pat, I doubt it is any bigger than the DTR mate
dtr engine out
Probaby wont start because it's upside down mate
dtr won't start
jont stick to one thread like NEV says, you have two on the go!! Post it in the other it has more replies Oh and that statement doesnt hep much at all, I'm closing this topic now...use your other
07 DT125X Splutters
Some sort of emissions gubbins I think, it wasnt on the DTR's but appeared on some of the RE's, you may find a tube from it that attaches to the exhaust at the front.
Cheers TTb, yeah it has a brand new front muddy and the chap said it was cheap as chips, it would benefit from a new headlight cowl, with white sticker...do I have to go to yam, or can I search for acerbis?
Riding on snow and ice is one thing but miles of salted roads to get there ...Aaarrrgghhhh
Cheers Darren, stand by to 'get pestered' Ohh...I prefer the top pic myself...more my style.
82 XT125 cutting out over 1/2 throttle
Thats the first time we have heard this, please yourself and good luck whatever it is, FYI it would not have been the first time a carb had been claimed to have been cleaned only to be found still blocked later in the thread!
RXS 100 starts BUT...
Coud be the right hand crank seal, check your gearbox oil for the smell of petrol and keep a check of the oil level in there
Mine do, thats why they have square tyres
Yeah took her for a spin, has some issues hopefully minor, notably Rear brake non-existant (seized) and a slight pull to one side, I hope its a wheel alignment issue, had a look and it didnt look properly central to me. I am in a good position...in that the current owner will keep it garaged for me until I sell the DTR I have been busy putting the DTR back to its bog standard and unmolested spec, de-restricted of course. I Have not got her advertised yet though. I am hoping that the DTR with all the spares and tweaked bits I have they will bring the lions share of the new bike price
That sure is a symptom of a main jet blocked,if it were me I would double check unless you are sure you saw daylight Unless of course you arent letting her warm up properly
Sounds like a blocked main jet even though you have cleaned the carb...could you have missed this...did you see daylight through the orifice?? I would say yes you need a battery, your generator wont be powerfull enough to operate on-board equipment without one. As for disconnecting anything....... when you get a battery you should reconnect that gadget we'll look at that later
New/old Yamaha owner
Greetings rdbug..
dtr engine out
Bet you'll not do anything so daft again mate...a hard lesson learned. so I suppose all the oil is running ot of you engine...and 2 stroke tank?
Battery Exploding
All that acid will be doing untold harm to your bike, give the area a wash with bicarbonate of soda solution!
IT 175 side stand mount needed
Good shout sir...cheap too
dtr engine out
never done mine mate NEV's your best bet. Cant you clear the water out with it in? it will save lots of time. Apart from removing the chain, all electrical plugs disconnected and pipes too I dont see whats your problem really
You'll be lucky but I expect you know that, perhaps you could have something made? Anyhow there's more IT activity here http://www.yamahait.com.au/forum/index.php
Help please peeps :(
told you so
- Hello!
'77 Yamaha dt400 question
An intro would be good
