Newbie with DT175MX..... Treat me gently!!
Super intro Yeah doesnt look a bad un, a rarity in blue too ...any questions just ask Greetings and ...Paul
DT 250 Questions
mines 1 1/2 turns and from experience its pretty normal
- give me your bike
dtr125 speedo cdi derestricting problem
youre gonna have to take pictures of the problems i dont understand what you are getting at! can you post pics tomorrow? and please remove your sig picture its way too big
life in the early 60'S
yes the days when we had factories, and jobs...and SMOG!
Not sure what you are saying here...do you mean bullet connectors?
does any thing work without the engine...the horn for example
- my dtr125 2002
air pipe mod for yzf r125
its fuel injection is it? with a carburated bike this would mean a headache with jetting and carb tuning to prevent it from running lean and overheating...how does this work with injected bikes? also eliminating the filter means all manner of dust, grit and contamination is free to enter the engine...not good for its longevity. There is also the matter of answering the question 'any modifications?' that insurance companies ask these days
yamaha dt50cc.mx lack o compression.
does it reach 100psi then? thats not bad in my book for a cold engine
'78 DT125 / 175 - Spot the Differences!?!
Good work Mike
DT175MX Refurbishing the swinging arm
yeah ok i made you one today
dt175 swingarm
At a guess I would say someone fitted a YZ swingarm
Non Starter - help please
I am wondering about the condition of the reed valve now, next time you get the carb off have a look there...maybe the petals are bent or seating on dirt and thus you are getting back pressure in the carb...its an easy check so have a look-see. You could also try it without the air filter fitted in case it's dirty or blocked, it will be fine for a small run around the block but obviously not prolonged use. also what did you mean all or nothing...of course you dont mean the overflow? nothing would be good there
The float height may be out but it really shouldnt stop it from starting...you could always switch the tap off when the carb is full. It may be that the throttle stop screw (the knurled one) isnt in far enough to allow air through, especially as the carb has been stripped. as for float height adjustment dont try doing it with the carb fully inverted because the weight of the float will push down the spring loaded pin in the needle valve, rather...turn the carb on its axis just until the float touches the pin without pressing on it and then measure the distance from the float bottom to the surface the gasket mates to on the carb body (below the gasket with the carb inverted), you will see a cut-out notch in the flange to aid measurement. Remove the float if adjustment is needed and bend the central tab slightly to achieve the correct measurement. This may give you an idea but use the measurement given for yours
My 1992 YAMAHA DT125R PROJECT
Sounds great NEV, shame I can't smell it
YBR 125/150 running lean
the clutch has nothing to do with running lean, you need to get it adjusted, perhaps there is too much slack in the cable?...perhaps it needs adjusting in the engine? Also check the oil level is correct.
Try a new plug first even though it is sparking. open the fuel tap and close it...you do have overfilling issues. you may have flooded the crankcase somewhat with attempts to start it so leave the plug out overnight to allow evaporation. use choke but no throttle or very little
DT 175 MX main jets
wow a 160 jet with an old type filter, has the filter cover been butchered drilled in the usual way ? is there a problem with how it runs then?
Brand New Yamaha YBR 125 - Gear Lever/Shaft "Loose"
Try adopting this method when down shifting. Pull in clutch Blip the throttle Downshift Let out clutch in quick succession
FJ1200 Fuel leakage
15 times duhh thats frustrating. I would think you need to sort out that vacuum tap first, is there any way you can pull off the fuel to carbs pipe to test it for leaking? alas I have no experience of working with these things. as for the carb it must be either crud in the needle valve leaking float (give it a shake) wear on the needle valve a n other? Can I give you a tip..mention the bike model in the topic title when asking for help...much more chance of getting other owners to read it I'll do it for you ...Paul
Blackhat250 in Ireland
Good pics Pat, somehow it looks a bit chilly but hey...April Your house look great but I dont know why you want so many cars
Greetings from Vietnam!!
Scoops copy and paste the BBCode on flikr for your pics...I did it for you
Identification
I have a 125 barrel and head if you want to swap
DT 175 MX main jets
Damnn yes Lee your bike will be running lean. if your aibox is the more modern one accessed from the left of the bike you need a 3U500 carb...and its not just the main jet!! also the needle and needle jet, pilot jet and the throttle slide cutaway are different. This is because the later air filter box is a less restrictive one as compared to the early version.
