Airhead
  1. yes indeed NEV and place the pin in the freezer...and the barrel with piston in the oven beforehand
  2. Nice one FR, dont see many, got a pic or better a vid?
  3. Greetings terry Got a pic of the 400?
  4. Nice one Blitz
  5. Greetings Columbo
  6. sound like possible clutch slip, you need to check for that before opting for a bigger engine strip, can you select 3rd gear start the motor pull on the brakes and let the clutch out with some throttle, the engine should stall against the brakes, if it doesnt it's clutch slip, you say its worse after oil change...did you use motorcycle specific oil? wet clutches on bikes need this as you may know
  7. Early bike Round sect swing arm airbox on right oil tank on left carb main jet 130 Later bike square sect swing arm airbox on left oil tank on right carb main jet 160
  8. access from the right is 130 standard, thats why 140 may be ok but 160 will drown it!
  9. C'mon NEV get the bullshit meter out!
  10. phone yambits tommorow, see if they are obsolete
  11. Doesnt sound good eh Pete, Try selecting all the gears with the motor off, just by rocking the bike back and forth...just the same?
  12. Its in great shape for such an old bike, spent all its life under a roof when not out on the road, ohh and pedals too so if it wont start after the tidy up
  13. there are part manual in the workshop forum, it would benefit you you to use them Geo
  14. This is the wrong forum Pete its for hellos here, would you start one in workshop Greetings and
  15. Can it be a project then? Details and pics...it would be a good place
  16. you need to take care here, I think the early one is wider than the later one
  17. so not the two plastic bushes the arm pivots on then ?
  18. Copied from the Gold Wing Forum (who marshall it) The annual Salvation Army Toy Run will take place again on the 19th November commencing from the Showcase Cinema Hyde Road (M12 5AL) and terminating at the Trafford Centre. There will be a breakfast from 9:00 am with assembly at 11:00 am and leave at 11:05 am. A presentation of toys and a short carol service will take place at the Trafford Centre on arrival. All the toys donated are used to help brighten up the Christmas of needy children across the North West. Donations are used to buy new gifts for childern who might otherwise not receive a toy this year. For full details have a chat with our very own Jim Cretney who has been involved with providing marshals for this event for some time. Tel 01613 361 318 or Mob 07845 872 415 Anyone local fancy it there will be a few of us lot there as usual and it would be great to meet others
  19. all depends on the airbox acces from the right was 130 standard access from the left was 160 standard The two carbs had other spec differences along with the main jet to cater for these different airboxes
