Gunk comin out of over flow pipe
never done one, done head gasket though, cant see it being too hard, drain the oil / mush, take off clutch cover, drain coolant (plug in pump?) take off pump...i suppose its in the manual you didnt answer my question though!
are what easy to change? head gaskets or water pump seals??
water pump seal gone mate I am assuming that 'overflow pipe' means engine breather pipe?
need longer brake cable sr250
DT175MX cable Total length to end of nipples = 132cm Sheath length to end of adjustment thread = 119.5cm adjustment thread 8mm Patterns easily available from ebay, yambits, wemoto etc
Think it needs a Wheelie-Bar?
think it needs a front brake too scott
- Wemoto.com
picture not there mate, copy the bottom box not the one with http at the front
where can you trace a motorbike with just the engine and chassis number
try yamaha uk first, they may have record of it and tell you the original registration number
Hi paul perhaps member 'paul dawkins' can help?
hello from the western isles and the owner of the most rotten ty in the world!!
might be worth asking here toby, worth having as a contact anyhow http://www.tytrials.co.uk/ see if theres a parts list in the sticky 'Parts manuals for yamaha bikes', there is often useful service data in the back of those books, part numbers may also be useful. I bet it's not easy trying to get stuff sent to the islands is it?
- my new bike
- my new bike
lets have a photo of the cable to brake drum fixing and adjustment, i'm wondering if a DT175MX cable would do it...readily available and cheap.
a swarm of nano quadrotors
they'll be in aldi for £40 soon enough
Electric clock setup xt125
it will be in the owners book i would imagine Ryan, if you havent got one you could possibly download one from yamaha uk
Mirror Mounts
its a sports faired bike merv
- Foamys new toy :D
ITS F**KING COLD!!!!!
No mate, its a starter jet that happens to say 'choke' on the knob
What bike have i got?
It is a DT125, cant you see something on the cylinder that says 123cc (for example)
yamaha yzf r125 clutch slip
could someone have put the wrong type oil in john? bikes have wet clutches as you know , so they need bike specific oils
Need experienced help !
it would be best to have it as a functional trials bike if thats possible, thats where the value will be with people interested in twinshock trials events. Where are you Gary?
Yamaha dtr125 no spark!!
Have you got a haynes manual, are you going to get one? There will be wiring diag's in there First post so feel free to do a quick intro in new members forum
dt50cc ignition.1981
does the plug spark when connected to the HT wire and just laying on the cylinder head? Its not normal practice to screw in the spark plug and then hold the wire 6mm from it, how do you know you are 6mm for example...and are you holding it by hand or have you fabricated something to keep a constant 6mm? Only an ignition system in great shape will jump the 6mm anyhow, in reality it only has to jump a tenth of that gap at the spark electrode!
- hi
Looks like im coming back to the fold.....
Very nice Dean, I believe that high mileage ones may have jumping out of 2nd gear problems, perhaps others will confirm this. She looks a real beauty mate I always liked them myself
