1968 Yamaha YL-1 Oil Question
my bike is 1979, its amasing how much progress was made in those 10 years lol
Greetings from South Africa
Greetings SD
XS11 - please help me identify
+1 1980 xs1100G diamond silver, one of the first with that vin# tha bars are 'ace bars' fitted the wrong way up!
- London Calling!!
- London Calling!!
- Dt tick-over/running problems (1997)
Greetings from sunny Edinburgh!!
Greetings Rob and how come you topped the oil up, what made you think it needed some? PM me and i'll send you a workshop manual, that should help you no end
Greetings from Australia
another L2, we have one here being resurrected Greetings and
hi,im new to biking and bought myself a yamaha xv 125cc 97'R'
I dont know of a manual for this john, theres one for the XVS125 but XV125??? is you fuel tank venting ok? and check your carb breather tube isnt plugged with crap
can any one tell me what this thing is???
you're welcome mate
if its pdf you can right click and then use 'search' it will go directly the what you search for, if multiple resuls step through using the forward/reverse arrow , for example search for neutral
XT 125 R Oil leak
sounds like you have several prblems, the engine idling fast and needing choke a lot and the oil coming from carb joint may all be related, you need to carefully investigate this situation, relace any joint gaskets in that connection but before you do just ensure the screws hoding this joint are tight enough you also need to remove the exhaust, replace the joint there and align the thing better so there are no gaps, this may also give to poor running as for oil in the airbox, clean it all out and check there isnt too much oil in the engine, there maybe an inspection window but bike has to be upright not on sidestand
Hi everyone
Greetings kaisermadra yeah lots of XVS125 fans in here
Just saying Hi 8)
Greetings Elffie and looking forward to the concourse restoration with added pictures
is your manual on pdf jimmy?
neutral switch i would think? yes just checked in the manual it's neutral switch check your manual jimmy
Headlamp conversion for 12V system
nahh its a different lamp NEO, anyway the uk lamp swivels on a vertical axis, that is how aim left is achieved on mine! pretty sure the French ones are the same as ours and they drive on the other side too! I think its just a thing the Germans had, they did it with other things such as fenders, indicators and chainguard on their model!
sorry merv i thought you were meaning the skew came from the bulb itself, you are correct that german market bikes had a different headlamp thats a good call I too have seen where someone cut out the lamp of a sealed beam and attached a bulb holder
My purchase.....
lookin good bertie @ gizmo that sig picure is way too big dude!!!!! and has it got an oil leak?
do bulbs have an beam angle merv, i always thought it came from the reflector / glass construction
Highway Hawks too Loud!
From experience I find this sheet baffle pack is way better than the loose fiberglass stuff, my bike suffered from noise and poor performance using that stuff...never again http://yambits.co.uk/exhaust-baffle-packing-p-839.html
New Member , Mavrick
Greetings rick
- New Member Saying Hi
I NEED INFORMATION ON MY YAMAHA TZR 125
might only need new rings and the ring grooves cleaning, dont rebore without proof of wear to the bore!
Dragons-eye zegt hallo
"Good day everyone wants me here voorstellen.Ik'm Dragons-eye from Netherlands proud owner of a xj bj 600 bj 85 and a 92 fzr 1000" (google translate version) Greetings dragons-eye
