where has barkwindjammer gone???
I went to a UFO sighting in Manchester on friday...Great gig
Back together again
A new set of rings and a bit of a tart up, shes good to go, went for a spin and someone in a car tried to kill me again!! thats twice now...first time out on the bandit and first time out on the DT
Hi, DT125R owner new to site
no you cant move the power band to where you'd like it best, just set it up correctly and then 'it is what it is' have fun...great bikes
Sputter sputter
Great news Richard, c'mon lets see her then! maybe today i'll put mine back together :spin2:
- 1977 Yamaha rsx100 - Kickstart lever issue
- Country Flags on Profiles
- Hello
Hi
Greetings florin, have you a son called bob?
Valves in forks!
leave them in, they are to pressurise your fork to your preference, not much pressure i wouldnt think...around 4-8psi at a total guess? Handy for a heavy rider with a full tank and tankbag on etc etc
petrol muppets!
you'll be pushing i reckon, all petrol is wiped out around here too
- engine chugging
Read this (your small print) it might just save your bacon
Thats bad mate, i'm with RAC but never used them yet so i dunno.....
how to remove xt 250 swinging arm bolt
give yambits a ring for your parts
TTR600 Rear Axle Nut Sourcing - Help!
another corker mark
yeah it probably has the same plastic bushes the DTMX has, thing is you will never get them out of the swing arm without trashing them anyhow so like i said...have a word with jason (cynic)...he did his this way
pictures would help paul
why are you removing the swing arm? is it fitted with black plastic bearing bushes?
Evening all
life begins at 40 they say alan Enjoy the YBR i'm sure you'll love it Greetings and
sometimes its best to place a stout tube over the head of the bolt (big enough for the bolt to pass through it) and rest this against a solid wall...then all your hammer blow will be effective on the bolt and will not be wasted in flexing the frame. Having said that though...1982....you'll be lucky but it worked for me years ago failing that, hacksaw (ask cynic)
yamaha tdr oil leak
yeah its easy..ask '2wheels' he did his...and in IRL too
yamaha tdr oil leak
most likely the gear shaft seal kearsy, get a new one fitted...not a big job normally
I would be surprised if it hasnt already been done . i'm sure if you use the search function you will find lots of ideas Greetings and
The Work has begun...
dont use add image button...just paste direct to your post
DT 125 R 1990 powervalve position
ok its late so gotta go, have a look here for setting up the diamond shaped on...post~ #31 with 3MB00 barrel. Not familiar with mixing and matching though but will check out your progress tomorrow. Aside from this I dont see why they should collide although I expect the bigger rebore the more danger of this happening? http://yamahaclub.co...arch_app=forums
