		1975 Yamaha RS100 turn signal issues!
		you could try using 6v 21w lamps, see if that works...the flash may be a little faster but you wont know unless you try it EDIT you could even put 21w lamps in the fronts only and leave the 17w lamps in the back, this would give approx the right load for the correct flash rate
		well it needs the extra load of the dash light...small as it is! thats why the relay says "relay says 6.4v 17wx2+3w " Note...+3w
		the dash indicator lamp needs to be working as well, its a 6v 3w i think?
		DT 250 Clutch Adjustment
		yes assuming its the same as the 175mX, there is a pointer at the end of the actating arm and a pip on the engine case, gently push the arm towards the front of the engine until it stop's. Adjust the clutch centre screw until the pointer and pip align. After this is done adjust the cable adjuster for 3mm play at the end of the handlebar lever. Now...how about an intro in 'new members'
		what is the battery voltage displaying on your meter?
		I agree with tony here, i suspect the chinese bulbs are 12v, if you have a multimeter a 12v bulb will display a higher resistance than a 6v one...if that were the case there wouldnt be enough current in the circuit to cause the relay to switch on and off
		Yamaha DT125R 2003/2004, same?
		so long as it's not off the DT125RE (elec start) model it will be the same as yours flaxxa
		barn find
		lucky find kearnsy, try wemoto for spares?
		The Hague
		425 miles, wow thats a long way merv
		DT 400mx
		greetings spoiley yeah not a big seller compared to it's smaller stablemate
 - Weak spark
 - Fzs 600
		Just a friendly hello
		Greetings rgaw
		06 DT125RE REBUILD TIME!
		wont need much keiran, about 300 miles i'd say. The concern is what happened with the first one? I've heard lots of times how DTR engines have had pv piston collisions! is this what yours had? some pics would have been nice, and of the piston (crumpet) crown too...doesnt sound good
		The Hague
		have a good one merv, bring back some interesting pics / stories
		new member go easy on me ;)
		Greetings Jay and
		Weak spark
		Oh my...youve only just bought the beggar
		Hello everyone - newbie gazzball
		+1 Greetings Colin
		pics of and info about my RS200
		silencers can be re-chromed too
		My Little Project - V50III plan to get done before my licence restriction ends
		i bet you could have got exhaust studs for half the price from wemoto though...for future reference
		Complete Newbie - Got my first bike today. Need some help.
		you may have to dampen the foam with oil and soak out any excess with kitchen roll? not sure...may be in the manual or ask the seller
		not a fan of those filters myself, i would never junk an airbox in preference to one of those, get a proper yamaha filter is what i say (if you need one)
		in march 2011 I had my wheels built with stainless spokes for £120 (2 wheels) http://www.manchesterxtreme.co.uk/ Forum member NEO had his done there more recently so perhaps an update on prices?
		Newbie viper79....
		Greetings viper and it's good to have dad on board eh
		DT175MX 1979 - Parts Question
		Ahh despite your topic heading 1979 it has now changed to 1980, in that case the carb id is 3U500 As for the oil in the crank? you mean in the gearbox it happened to me once when the seal had popped out of its location in the oil pump drive shaft, you'll have to take off the right hand clutch cover to see (drain oil first) It's not worth considering any other faults until you sort this Have you posted an intro in 'New Members' ?
