Airhead
  1. then i am guessing you need a new ignition switch unless you can somehow clean the contacts...because the jumpering excercise just bypassed the switch and the associated wiring,you have stated the associated wiring and plugs are clean you could take an ohms reading of it all, take out the fuse and measure between the fuse holder clip (loom side) and the brown connector on the relay, it should be a very low reading 0.5 ohms at a guess
  2. i think the 20mpg ones have leaking gas tanks !
  3. me too mate but i was just answering the question as asked
  4. you had me confused saying its a 1980 bike, these did have the square sect swing arms as i thought..its a 1979 model thats why the oil tank is on the left...someone fitted a later arm
  5. Hi
    Airhead replied to jester.'s topic in New Members Welcome Area
    Greetings jester and how are you liking the big draggie?
  6. Greetings spark yep, great bikes
  7. Greetings nate, yeah its quite heartwarming to see such affection for small animals from the young generation
  8. yes there are several ways of checking one is to drain the oil remove the engine take off the two engine cases chock up the engine on blocks until the cylinder base gasket face is approimately level (preferably in a tray) fill the crankcase with diesel and watch the two sides checking for weepage how does that sound?
  9. you sure the oil tank is on the left i dont see it? 1980 should be on right shouldnt it?
  10. thats why i asked you cant just nip these nuts up you have to get a good hold of the rotor and tighten them to the recommended torque...and thats pretty damned tight. if they come loose and the rotor also comes loose you will damege the woodruff key and possibly the recess it sits in and also risk damaging the magneto coils themselves due to heat generated through friction caused by the rotor rubbing the iron cores....hope not! I think you should investigate this area now and not strip that motor fully again unless you are sure about big end play!...how are you judging this 'play' ?
  11. I doubt it isnt the original one Different swing arm different shock absorber different chainguard what side is the oil tank on? what is the vin number?
  12. Rubber? aghh i'm out of my depth here, usually they are heat proof aluminium / fiber jobbies
  13. Get it rebuilt at manchester xtreme with new ss spokes
  14. not a fan of them myself
  15. yep it would need a gasket fitting between the pipe and the barrel
  16. how about an intro in new members forum? cheers
  17. you need to release the spring tension (take care) Then up end and drain the oil out then remove the allen headed screw at the bottom and pull out the stantion, then the seals can be removed. Take care not to damage / dent the top of the slider when removing the seal. All just a guess, this is how my old bike is......
  18. so then...it is working with the jumper and not without it...is this correct
  19. pretty sure these ship worldwide turs, have a mooch around here http://www.wemoto.com/bikes/Yamaha/FZR_1000_EX_UP_3LE/91-92/
  20. welcome in fella, yeah they are a great looking bike, hard to believe they are only a 125. feel free to post up a pic of your pride n joy
  21. Yeah keep taking the tablets Brian welcome in mate
  22. Good stuff mate...Off now
  23. copy the very bottom 'field' Jason, the one beginning ...not the one beginning http
  24. not bad Jason, whats the plan? get her roadworthy?
