Sorry for being absent...
why not just turn the throttle stop screw in about 1/4 of a turn? After all that's what it's for
Fazer won't start
yep...new battery I would think
Uh, so close. Now its electrical...maybe.
If you are taking your carb off take the reed block off also, check they are not stuck or bent while you're at it Have you had your flywheel magneto off?
fast DT175?
Thats fast by my standards lol, what state of tune though you didnt say Greetings wally and
The question asked a 100 times.
and me, mervyn (pilningas) has toured all over the place on one of those
so the carb is overflowing! just turn off the fuel tap for now...if the bowl is full theres enough in there to start the bike and some Just because it was overflowing why does this mean it isnt being drawn into the engine? I really dont like the sound of that!!
FZ6 with a dead ECU for its third birthday present
Great news dolau, now wrap up that cable connector well, have you considered that yucky but extremely effevtive greasy tape stuff http://www.google.co.uk/imgres?imgurl=http://www.cromwell.co.uk/images/product/AVN/981/AVN9817100K_0.jpg&imgrefurl=http://www.cromwell.co.uk/index.php%3Fq%3D0%26p%3Dbrowse%26c%3D040110&usg=__bdBXZH_AkVa_zHlwWOJ6tgDXWP8=&h=500&w=484&sz=55&hl=en&start=2&zoom=1&tbnid=7v3-xC7JqtGVIM:&tbnh=130&tbnw=126&ei=hPBiUMfQJqmg2AX36IDQAQ&prev=/search%3Fq%3Dwaterproof%2Bgrease*%2Btape%26um%3D1%26hl%3Den%26safe%3Dactive%26gbv%3D2%26tbm%3Disch&um=1&itbs=1
DT175 to 125MX change
I would just do the main jet for starters, this info is for a 22mm carb and you have a 24mm, ....... is this fir a mk2 airbox Tony?
My old YZ250 on track
Great vid and super stills have fun...never too old just get it done eh
its small enough to try a bump start too eh?
yeah I was thinking 130 will be more like it, try it WOT when you can and see what its like, buy a few genuine mikuni jets from allens they arent expensive, start with 140 if you like and go down in 5's from there watching plug colour and feel / temperature 130 is actually 6 sizes smaller...they increment in 5's at this size as you know, you should fit the biggest one that it will run sweet with at WOT
Does it run OK at full throttle? I would think the 160 is too big for a main jet, doesnt it 4 stroke and stutter at WOT? What is the correct size MJ for a 125MX with a mk2 airbox did you research this?
Feeler gauge
Have you checked that by using combinations of those gauges you can get the right gap specification for your bike grouch?
Hello YOC
its a 1999 speed triple ya cheeky git John!...see his 'bikes' llol
Have you put new rings in the piston...perhaps It's a bit down on compression? Take out the sparkpug tonight and leave it out It's a good bet you have flooded the engine after todays endeavours!...let it evaporate off. tomorrow squirt a bit of oil in through the spark plug hole...about 1 1/2 teaspoons full...if the rings are a bit worn it will help seal them to gain some compression to start...full choke and no throttle (or hardly any) is the key
Hello YOC
Greetings captain triple wow one owner from new not may of them around, me too start a thread about your bike in the classics forum, this is for the intros and thanks for posting one
Where Did the Oil GO ?
you wont even need a flywheel puller if you only change the 'wet' right side seal
Hi all, another newbie
Greetings Jamie show us then
I"v joined DirtyDT,, on the dark side,
just a 2 stroke junkie blackhat....
Should my tank really have 'YAHAMA' on it?
if your tank has 'YAHAMA' on it...it will be pretty unique Greetings and so this DT125E, what does it have registration number? V5?...just what?
1999 yamaha sr 125 starting problem
you may have to short out the disconnected connector (loom side) not sure have you got any electrics working...horn, lights etc
TZR 125 YVPS problem
so the filter made no difference?
Dont go too far without the filter, I meant try it a short ride 2 - 3 miles is plenty...just in case it makes it lean
Hmm well it's leaking worse than you imagine then ! Yeah the red light is just for 2 stroke oil and Is always on in neutral
are we talking about 2 stroke oil, thats what the red light is for. or gearbox oil which will be affected from your enfine leak
