Biker caught doing 104mph past a horse
No boon, that would be money laundering
Yamaha xt 125 x digital speedo not lighting up
I wouldnt order the speedo before knowing that the unit has the 12v power that it no doubt requires...Have you guys not thought about that?
Duff links to service manual download sites
howy is all fixed up now
Xj600 won't start when hot
is it high mileage? can you get a compression test done...though I dont know what figures you should be expecting here!
Kam I have no idea fella but I wouldnt be at all surprised if it requires the tank to be removed, 'blackhat' made a valid point about possible low compression though...this can lead to difficulty in starting
Try it without the air filter Kam
NEW BIKE OWNER
a belated greetings howy to the YOC forum
Hi every one - really need some help with a non firing dtr after new piston @ rings
As daft as it sounds try another plug, my old DTR completely refused to start once, nay it didnt even try to start. Fitted a new plug and away she went, put the old plug back and away she continued to go!!! some things you just cant explain
dire YB100 electrical problems...
Not at all mate, you're very challenging
It looks to me that you need a running engine for the pilot light and the meter lights on this model, thats why you are having issues...yours doesnt run does it?
- dire YB100 electrical problems...
where shall we start Iain?...the headlight?- dire YB100 electrical problems...
I need that wiring diagram ato can you email it me?- Newbie from Teesside
Greetings Gordon- Hellllllllloooooooo !!!!!
Greetings wolf, sorry to see you're having problems mate- 78 DT175 Heat seize
me neither, well said 'V'- Multiple problems
have you checked the oil level?- just when you think it cant get worse.... your clutch goes
Great stuff Sam It's been a bit of a journry for you eh...It's always nice to see one of the DT's returned to the road...Hats off to ya and dont forget to post up a piccie eh? keep in touch Oh yeah...if the clutch is dragging a bit and you havent over filled the oil and if it doesnt get better after youve run the motor in why not try some thinner oil http://www.opieoils.co.uk/p-934-motul-transoil-10w-30-lubricant-for-gearboxes-with-wet-clutch.aspx- my new bike
- Adele v Guns 'N' Roses mash up
Haha yeah that thing, I removed mine years ago, I bet theres not many of those around these days! By removing the lid, you have effectively removed yours too now I'm tempted by the meter I must say, £160...whats that? about two dyno runs these days? £145 on fleabay http://www.ebay.co.uk/itm/INNOVATE-MTX-L-AFR-Wideband-Air-Fuel-Ratio-Gauge-3844-/300506017816?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item45f78df018- eBay
wow thats impressive venture, I've though in the past that it would be great to have a tool that analyses the exhaust gasses but this is the first time I have seen anyone reference one in a forum... so A/F...is this air to Fuel then? Tell us more about this tool, make / model / etc I recently tried with my airbox lid jacked up because for obvious reasons I didnt want to drill it, maybe you'd want to do that too if you're running without it now? I removed the seal and placed 2 off 1mm plastic washers on some slightly longer mounting screws drilled small enough so that they had to be screwed down the thread so they didnt fall off I gave up in the end because I couldnt seem to be getting anywhere with it...perhaps I needed an A/F gauge...who knows? anyway the airbox lid unadulterated- Fazer won't start
Great, thanks for the update jamjar- De Restricting my DT125R
Good news Ken, thanks for the feedback - dire YB100 electrical problems...
