Ducati Monster 796 Walkaround and Warm Start - Dirty Version (No Baffles)
very nice rohan it sounds great too
Problem with clutch lever resistance xt125 x 07
and on another note again, so did you align the plain plates with the smal bump in a way that they are equally spaced around the basket?
Dtr overheating
Goos one ken glad you got it fixed. just get a hold of the screws of the thermostat with some vise grips or failing that drill the heads off them and get a grip of the screw shafts when the cover is off Merry Xmas
nothing to do with it i would say...you may have done something wrong when re-fitting the plates. and on another note...did you fit the plain plates with the 'tab' right? (this is another story though)
Dtr overheating
yeah I would be surprised if the head was warped, if that was the case I would expect there to be loads of bubbles in the expansion tank as the compressed gasses are pushed into the cooling system. top up the radiator and squeeze any rubber hoses to it with a pumping action, re top-up if the level drops.
Get my new thundercat today!
Yeah its not been a bad day for a change SYLO
Ethanol Blended Fuels!
should have gone to specsavers
Rad Cover Fitted to FZ8
I like it as it is...on the other hand i would like it painted black with the FZ8 in gold
I read something interesting today http://www.groups.tr-register.co.uk/wessex/ethanol-update.html so in 2013 I'm gonna be using this in the old DT http://www.millersoils.co.uk/automotive/tds-automotive.asp?prodsegmentID=911§or=Classics
78 DT175 Heat seize
Yes mate I made it from a piece of polished stainless cut from an old broken tea urn that i binned at work..not laser cut but thanks for the comment I will post up something interesting about ethanol petrol next
- bolts..
- bolts..
bolts..
I dont think they are metric fine, they arent on mine and theres no reason they should be...and they should be 25mm long
bolts..
http://www.yamahascooterspares.co.uk/spares/partImage.asp?GPN=975070652500&uID=0
- 78 DT175 Heat seize
Great stuff Richard, let us know how she runs and in particular the temperature. I have an inkling that mine needs a new crank seal (magneto side) an she's 'hanging' at idle briefly before settling and kangarooing on the over-run, It will be interesting to see if replacing it reduces the running temperature any- Inroducing Myself
Greetings Sean and in- DT400e jetting
I find that what was a standard jet size back in the 70's should be increased a little with todays crap petrol even if the rest of the bike remains at stock settings and equipment, why not try a 190 195 or 200, genuine jets are cheap as chips Maybe even retard the ignition by 0.2mm or so- YAMAHA FZR 600 GENESIS STALLS WHEN PUT IN GEAR
WOTS ALL THE SHOUTING!!!, IS YOUR CAPS LOCK STUCK ON check the stand switch with a multimeter, unplug it and see if its doing its job eh?- Merry Christmas
- bolts..
- bolts..
do you have a parts list for your bike?- x-referancing part numbers from different bikes?
Err... no I dont, only on my clock mate- x-referancing part numbers from different bikes?
hey Steve, somewhere amongst my stuff I have a new tail light bracket that just may be the same, I cant get photobucket to post for some reason http://i294.photobucket.com/albums/mm116/oldgitonabike/DT175MX/Cycle%20Parts/201_1716.jpg http://i294.photobucket.com/albums/mm116/oldgitonabike/DT175MX/Cycle%20Parts/201_1717.jpg- Merry Christmas
Thanks Keith Yeah I wish all of you a merry Xmas and a happy n healthy new year May the sun shine on us all in 2013 and i'm looking forwards to our 'meets' in 2013 - 78 DT175 Heat seize
